![]() | Home > Maintenance & Modifications > Corrosion in rear tub |
donmacn Member Since: 06 Nov 2017 Location: Nth Scotland Posts: 1852 ![]() ![]() |
On mine (1994 SW) I had a lot of the same white pasty 'gloop' underneath the 2nd row seats. Definitely catalytic corrosion where the alu. tub floor met the steel of the chassis supports and middle cross-member.
I fixed this with a repair panel from YRM (might be pics on my rebuild thread, but this job might predate my Def2 membership) Later I found holes where the 2nd row seatbelts bolt through onto the chassis. The only thing I 'spilt' there might have been salt water draining from scuba diving kit in my more careless days. When I fixed this, and on anything subsequently, I've made very sure to put PVC/nylon gaskets between any steel and alu. Really surprising over time to find that there was none of this done at the factory. More recently I've fitted a whole new floor and crossmembers. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
lonewolf Member Since: 23 Oct 2013 Location: North East England Posts: 210 ![]() ![]() ![]() |
Apologies due.......I missed some of the replies relevant to this posting in February (not sure how as I usually get emails to inform of replies).
Some of your posted pics and written descriptions mirror my problems, pasty gloop etc. I must get the rear seats out along with the rubber floor mat and have a good poke around. I’d be interested if anyone knows if you can get replacement floor panels and the raised squared off sections at the sides.... Just curious. I’m of a mind to plate over with aluminium if it’s not to bad, as was suggested. Thanks again for your input ![]() |
