Home > Off Topic > High charging voltage |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1768 |
Definitely high enough that it won't do the battery any good!
Is it a freshly charged battery, and are there any other electrical loads? I seem to remember that the voltage of a dynamo will increase when it's lightly loaded. |
20th Feb 2020 4:12pm |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2532 |
No load on the battery. The battery voltage holds at 12.6. Once started the battery voltage increases over the next 30 secs or so and settles at 15.9v Defender 90XS SW
20th Feb 2020 4:20pm |
lohr500 Member Since: 14 Sep 2014 Location: Skipton Posts: 1325 |
I'm no expert but it does sound high. I searched the www and the info seems to suggest a max charging voltage of around 14.5v It makes me think that the voltage regulator has been incorrectly set up when manufactured.
Especially as your battery is giving a good voltage reading when not being charged. I guess if you have one, you could always try a different battery and see if that also gives a 15.9v reading. That would eliminate any question of it being battery related. |
21st Feb 2020 3:14pm |
I've emailed the supplier of the voltage regulator as I believe he may have supplied me with the wrong regulator. The original manufacturer was Lucas which is no longer available. The one I have fitted is a copy, made in India but unfortunately does not have a part or article number on it. The original Lucas ones were available in 11 amp or 22 amp rating so I suspect they may have sent me the wrong one or indeed as lohr500 says there may be a manufacturing fault.
I would like to get the voltage down to 14.5 or just below as I don't want to have to buy a new battery or dynamo. Defender 90XS SW Mini Countryman Cooper S Morgan Plus 8 |
21st Feb 2020 4:17pm |
