Home > Off Topic > Any electricians out there? |
Muddybigdog Member Since: 11 Apr 2014 Location: Suffolk Posts: 1018 |
We are experiencing some weird electrical issues in the house;
- Reading lamps switching themselves on/off rapidly even though they are switched off? - Fan oven, keeps switching itself on (fan noise) when everything is switched off? - all lights flicker when on? - switched on washing machine, made a few weird noises, then drained itself and switched itself off, after about 2 minutes from starting? - microwave making strange sounds when in use? any ideas chaps? Jumped ship to reliability - Mitsubishi L200 Puma 90 XS - Sold D3 - 2.7 S x2 (both Sold) Freelander 2 HSE - Sold Freelander 1 - Sold Disco 2 - Sold |
16th Feb 2020 2:29pm |
Thanks Rashers for the heads up, no idea about PME supply, but called UK Power Networks, they are sending someone, they too think its an earthing issue Jumped ship to reliability - Mitsubishi L200
16th Feb 2020 3:29pm |
Rashers Member Since: 21 Jun 2015 Location: Norfolk Posts: 3502 |
That's what it sounds like. Glad you got someone who knew what they were talking about
School time! PME or TN-C-S is a type of earthing system which is favoured by most supply companies as it in essence uses a combined neutral and earth supply cable into the consumers property. It is split at the consumers fuse next to the meter. In some instances, if there is a fault on this combined neutral and earth cable, it can cause a whole shed load of issues. Odds are, your electrical supply is from overhead cables and storm Dennis has probably caused the fault. |
16th Feb 2020 4:40pm |
ak615 Member Since: 22 Aug 2018 Location: essex Posts: 178 |
You could also ring Most Haunted
16th Feb 2020 7:53pm |
My mate said I should call Derek Acorah or Yvette Fielding Jumped ship to reliability - Mitsubishi L200
16th Feb 2020 10:01pm |
Doc P Member Since: 03 Apr 2016 Location: Midlands Posts: 565 |
You’d need Derek Acorah to speak to Derek Acorah now because he’s one of the ‘departed’ 😳
16th Feb 2020 10:42pm |
