Home > Maintenance & Modifications > Recommendations on light bars
bear100
So as title really
What light bars are we all using and why?
I’ve got an expedition on the go and the time is soon upon me to tackle lighting Very Happy Very Happy
Needs to lighten up a good distance with good spread, good quality, durable etc
Front mounted on rack, bumper mounted with DRL and rear work lamp
I have used Lazer lamps in the passed and they work really well but do come at a premium, which is ok but if there are alternatives just as good or as best to I may give it a try Very Happy 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #815211 15th Feb 2020 7:46am
Welshsurferdude
Wales
I bought this Gemtek 40" from Australia. think it was about £100 odd.
Its very bright indeed!
I am currently saving up for some Type X Pro's also from Australia from a company similar to Lazer
but a lot more reasonable called Stedi. They look amazing!
 2008 Santorini Black 110 XS USW (Sold)
2015 Discovery 4.5 Black pack Firenze red XS
2008 Corris Grey 110 XS USW (sold)
2011 Santorini Black 110 XS USW (Sold)
Post #815212 15th Feb 2020 7:53am
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
I bought some light bars from this company on eBay : https://rover.ebay.com/rover/0/0/0?mpre=ht...3240305193
Cheap and cheerful but very bright with good range. The brackets have rusted a bit but the light unit itself is still fine and for the price, my plan was to replace with Rigid light bars but as these are still working I don’t see the point.
They are not “e” marked/approved so off road only.
Pics of them mounted in Buggsy’s thread Thumbs Up 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #815215 15th Feb 2020 8:22am
^^^^ Those are the same ones I have, flood and spot. They are surprisingly good never had a problem at all. I’m quite happy to live with a paint touch up due to the cost.
The USA, OZ & NZ have good markets for these too, but the carriage and taxes are a killer on some items.
If they do need a bit of cosmetic tidying up they are easy to whip off if you use the correct connectors.
I used 50A Anderson connectors on mine for current capacity with waterproof boots.
The joint between the two boots use a run of quality electrical tape with a tear off tab and that seals them up superbly and should I want to remove them it’s just a case of taking the take off, unplugging and removing. There is even temporary use caps too to keep moisture and wet out whilst you sort anything out. I’ve had about 3+ years at least now of trouble free lighting with them and they’ve been exposed to all weather conditions. Equally I’ve had just as good service from my Nolden LED headlights too. $W33T $0U7H3RN $UG4R
Post #815257 15th Feb 2020 2:03pm
