Home > Wheels & Tyres > General Grabber X3 285/75R16 - Any lift required on my 110?
sconie
Sorry for another tyre post but I am finding mixed answers via the search! I've been offered an upgrade to the General Grabber X3 as the tyres I ordered are out of stock for a few weeks. I'm looking for a definitive answer to whether these tyres fitted to 16x8 modular with an Offset : ET + 8mm would need a lift?
if so I can ask for a smaller tyre fitted. If so what size would you recommend?
https://www.paddockspares.com/285-75r16-ge...-only.html
Thanks again in advance.
Sconie
Post #815069 14th Feb 2020 10:26am
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
I have 285 75 r16 tyres on 16 x 8 ET0 wheels fitted to the 110, there's no clearance issues with standard height springs so you should be fine Thumbs Up 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #815601 17th Feb 2020 11:21am
ickle
ditto.
Post #815602 17th Feb 2020 11:24am
sconie
Brilliant thanks for the replies guys 👍
Post #815617 17th Feb 2020 12:56pm
jst
They will fit without a lift and for gentle off roading and tarmac will be fine. You may find tyres rub return edge on rear mud guards on full rear axle flex though. Non arb. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #815637 17th Feb 2020 3:42pm
sconie
Got my wheels and tyres fitted today, love the look now. They do however catch on full lock so I'll need to study forum posts as to how I adjust the steering stops.
Post #816148 20th Feb 2020 2:02pm
markb110
sconie
It depends on what you are indending to do with your truck.
On my previous 110 I had 255/75/16's. So same height, a little narrower.
I also had a two inch lift. The picture show the tyre snuffed into the wheel well. A wider 285 would have rubbed on the inner wheel arch and may have pushed out the outer wheel arch.
A 285 also drags along the sides of ruts more than the 255.
Again it depends what you are planning to use your truck for.
Good luck
Post #816155 20th Feb 2020 3:23pm
