![]() | Home > Off Topic > M3/M25 traffic |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
brings back memories. i used to get to the M3/M25 junction by about 07:30 otherwise it was normally backed up, i am driving from the east.
most days i took off down the A3 to Guildford and then cut across to the M3 via the A31 and A331........usually much clearer traffic and quicker. good luck! BM52 |
kingofthesparks Member Since: 06 Jan 2011 Location: Very close to Watford gap services , northants Posts: 987 ![]() ![]() ![]() |
Not as bad as where the M4 joins the M25
noworries4x4 Member Since: 24 Dec 2010 Location: Newton Abbot Devon Posts: 1195 ![]() ![]() |
Its been
![]() Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle Weekends 07MY L322 TDV8 Vogue SE Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 ![]() ![]() ![]() |
[quote="BigRuss"]Is anyone able to tell me what the traffic is like where the M3 meets the M25 in the mornings?
Cheer Russ[/quote Depends on direction of travel. If you're on M3 london bound its horrendous, often back to Junc 4 [15 miles!] between 07.30 - 09.00 likewise if on M25 clockwise its a ![]() M3 coastbound or M25 anti-clock never seem to bad.... unless something go's tits up of course. Guns and Landrovers .... anything else is irrelevant. |
I do this everyday, you need to be thru the junction by about 6:45am (M3 to M25) otherwise be prepared for 20-25 mins delay.
if you are doing m25 to m3 then it's ok because you are against the main traffic - However, it only takes a caravanner (like tonight) to screw the whole thing up because the "thought police" highways agency will get on the scene and screw up the flow of traffic. I am guessing this is for a holiday or are you planning on doing it every day ? if you have traffic on your phone, keep an eye on it - fridays are the best day and now the holidays are here, its better. |
Probably pass you every morning then bpman, im southbound
![]() mind you, not at 06.45 so i guess not ![]() |
