Home > Maintenance & Modifications > Heritage style grill badge fitting
Crossfit_Pete
United Kingdom 2007 Defender 90 Puma 2.4 CSW Firenze Red
I’m going to give my Defender a facelift and have decided on a heritage style grill.
I’ve purchased a copy from eBay and will be taking it to be painted tomorrow. When it returns I’ll be fitting and old style badge.
There are holes for riveting but I’m worried about riveting onto plastic. Has anyone fitted a badge to one of these?
Post #813671 4th Feb 2020 10:11pm
UtilityTruck
I was going to, and thought the same. I think 3M number plate tape might be a good bet. I think the factory badges might be riveted, but who knows if the copy grills are as strong... 2014 Keswick Utility 2.2
Post #813680 4th Feb 2020 11:07pm
Co1
I imagine that some repair washers the other side of the plastic will be enough to spread the load.
Post #813688 5th Feb 2020 6:10am
When I fitted an alloy badge to my mesh grill, I made up a little plate to clamp it in position:
I covered the backs of each with foam to protect the grill coating:
 Darren
Post #813717 5th Feb 2020 9:13am
UtilityTruck
Nice job there! 2014 Keswick Utility 2.2
Post #813737 5th Feb 2020 11:05am
Bluericky
United Kingdom 2009 Defender 110 Puma 2.4 DCPU Keswick Green
Pete I did precisely the same thing , putting the badge on the heritage grill . I riveted it but placed good sized washers behind . https://www.instagram.com/hustynminepark/
Post #813853 5th Feb 2020 11:57pm
Bluericky
Post #813854 6th Feb 2020 12:00am
Crossfit_Pete
Thanks for the help guys, it’s currently at the painters but when I get it back I’ll take a proper look. Washers seem like a good idea but might just use number plate tape, that’s what is holding the rear badge on.
Post #813862 6th Feb 2020 7:08am
My only concern with numberplate tape is that the surface area that it'd be sticking to on a grill isn't great. It would, at least, be very easy for somebody to prise off but might just fall off. Darren
Post #813866 6th Feb 2020 8:11am
Bluericky
Definitely rivet it , just use small soft rivets with a washer each side .
Some light fingered individual will walk off with it otherwise , they’re not cheap . At least mine wasn’t ! https://www.instagram.com/hustynminepark/
Post #813874 6th Feb 2020 9:01am
