Home > Off Topic > the fountain of all knowledge - painting
Caterham
help.
I need to turn around some painting in a hurry.
I've got some 0.9mm sheet steel arriving from laser cutting and need to get a coat of paint on asap. I planned simply to whack a coat of smooth finish hammerite. my plan was a single coat no prep would do it but am I being overly optimistic.
this isn't going to be seen close up just needs to be reasonably corrosion resistant as it's going to be outdoors albeit under cover.
any thoughts recommendations please Thumbs Up
Post #813483 4th Feb 2020 8:38am
sako243
Painting is rarely anything to do with the paint itself but the prep work. Make sure it's all clean and dry first.
I'd personally just buy a rattle can and put a couple of coats rather than a single one. Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #813489 4th Feb 2020 8:50am
Caterham
so the steel will be clean / dry. do I need to do anything else ie put white spirits on it or anything?
a couple of coats of hammerite it is then Thumbs Up
Post #813493 4th Feb 2020 9:04am
X4SKP
Hello Caterham
Hammerite
Will be OK for your needs, but as time is your enemy, this is not fast drying, 12- 24hrs to handle
1 month or so to fully harden, (more than likely) even if bolted in place by then.
DTM
There are a number of direct to metal paints that will do the job, I've used this with success for years.
https://www.paints4trade.com/direct-to-met...tid=259052
Note:
Your incoming steel part/s will have a surface film of oil (almost certainly) even if you can't perceive it
degrease this, thinners, alcohol...(not white spirit), key the surface with wet and dry before painting.
Good Luck SKIP
Post #813494 4th Feb 2020 9:28am
grafty99
Any paint will require at least some prep to be successful. Lazer cutting leaves sharp edges which will rust first. For longevity you'll need to round the sharp edges and key the entire surface. White spirits will leave an oily residue which will prevent proper paint adhesion.
For speed, file the edges, key the metal with 120 grit abrasive and then degrease with panel wipe or rubbing alcohol Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #813495 4th Feb 2020 9:41am
Degrease, wet blast to prepare surface and blunt the edges, acid wash, prime, and paint. Probably ott in this case, but will exceed oil industry off-shore standards.
If the parts are laser cut, why not get them ZP&P or YP&P, or even galvanised?
Post #813506 4th Feb 2020 10:43am
sako243
If it's a big 0.9mm sheet then galvanising stands a fair chance of warping it without a jig to hold it down. Ed
Post #813507 4th Feb 2020 10:45am
Good point, I'd forgotten he said it was flimsy. Blasting would require skill too to prevent damage.
Smooth edges, degrease then spray would be more appropriate.
Post #813518 4th Feb 2020 11:55am
windy81
Wales 1992 Defender 90 200 Tdi HT Firenze Red
etch prime and paint. fast as fook
Post #813521 4th Feb 2020 12:02pm
Bluest
Are you sure it'll come clean? I worked at a laser profilers and all our mild steel was oiled to stop corrosion. There'll usually be a little pip on each profile where the cut started and finished that'll need filing off too. 2007 110 TDCi Station Wagon XS
Post #813530 4th Feb 2020 12:59pm
Caterham
Shocked
got the steel plates now. I only have tomoz to sort.
/\ thinners mentioned which makes me think white spirit but /\ suggests not white spirits.
thanks x4skp. looks like a trip to toolstation tomorroz to pick up some dtm paint.
any help on the alcohol much appreciated thanks everyone. Thumbs Up
Post #813635 4th Feb 2020 7:33pm
Bluest
I’d use xylene thinners to clean the metal. You can get it in Toolstation etc. 2007 110 TDCi Station Wagon XS
Post #813638 4th Feb 2020 7:38pm
sako243
Thinners only required if spraying and mixing yourself (I.e. with compressor).
I've used brake cleaner in the past as it's meant to get rid of all oil residue for obvious reasons and then evaporate off.
One thing not mentioned so far is if the surface is very smooth it might be worth rubbing it over with some sandpaper to provide better adhesion. Ed
Post #813639 4th Feb 2020 7:39pm
Caterham
/\ thank you for the sand paper / smooth surface.
I presume the thinners is still a good idea on the metal even if using a rolling (or not ?) Thumbs Up
Post #813697 5th Feb 2020 7:39am
sako243
I wouldn't bother with thinners unless you're spray painting, usually there's just no need.
To be honest I'd just pop down to Halfords and grab a couple of rattle cans and put a few coats on with those. There is a point where you do too much, basically as long as the surface is clean and keyed the paint should stick. Ed
Post #813704 5th Feb 2020 8:29am
