Home > Technical > Part number for D90 300 Tdi fuel sender
JackW
United States 1998 Defender 90 300 Tdi SW Coniston Green
I'm looking for the part number for a new fuel sender for a Defender 90 with the rear mounted plastic tank used in a ROW 1998 model. Its a transition year when the TD5 was starting production and there was some overlap between the Tdi and TD5 models. I think (may be wrong) that the TD5 used an in tank lift pump but the Tdi had a lift pump on the engine so the tank module only has a sender. I also need to know which gasket and locking ring to order.
Thanks for any help - trying to fix this before I run out of fuel on a lonely road somewhere... I've come close but made it to the diesel pump just in time at least twice.
Post #813316 2nd Feb 2020 10:35pm
Will@LRW
 1997 Defender 110 300 Tdi CSW Alpine White
Here you go: https://www.lrworkshop.com/parts/WQB100430
And for the other parts:
https://www.lrworkshop.com/diagrams/land-r...gs_53498#4
Hope that helps LR Workshop
Find a Defender's history and spec: https://defender.lrworkshop.com
Post #813317 2nd Feb 2020 10:52pm
JackW
Thanks very much - I had that part number written down but didn't have any way to confirm it was the right one.
I want to have one in my hands before I drop the tank. It looks like there are two different sealing rings - ESR3806?
Post #813320 2nd Feb 2020 11:04pm
