Home > Maintenance & Modifications > rear door seals and back door hinges. |
Stiff1 Member Since: 09 Dec 2014 Location: Cornwall Posts: 597 |
I had the same dilemma, went with the Bearmarch ones and indeed they are useless. Doors will not close without an almighty slam. The length between the welds is just all wrong.
29th Jan 2020 11:29pm |
Fabio Member Since: 05 Aug 2011 Location: Somerset Posts: 589 |
Hi Stiff,
Thanks for the reply. I Bought the bearmach one anyway. Hopefully it will do for what i want, because since it went to land rover for the repairs at the end of the corrosion warranty, one of the back doors never really closed properly i have had it off and tried everything to get it right but haven;t been able to. Fabio |
2nd Feb 2020 5:34pm |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2185 |
The cheap seals just do not fit, I tried the Bearmach ones and Exmoor Trim ones both where over an inch too big across the top! Dont waste your time and money but genuine LR ones.
As for hinges you cant buy them coloured. You have to paint your own or have someone paint them for you (roughly £350 for 4). That or buy aftermarket ones (£500+ for 4) Instagram @defender_ventures Empire Tuning - Agent |
2nd Feb 2020 6:14pm |
Hi Bankz
I have bought them. But I do believe they’ll be rubbish. My worry is the door doesn’t shut properly and if buy the genuine ones they’ll be chewed by the door again. That is what happened to the one that is there, since Land Rover Yeovil messed about with it. Fabio |
2nd Feb 2020 6:36pm |
Then you need to adjust your doors. Time consuming process
Ill be surprised if they fit Instagram @defender_ventures Empire Tuning - Agent |
2nd Feb 2020 7:43pm |
I know, I’ve tried but it didn’t go very well.
Thank you. Fabio |
2nd Feb 2020 8:04pm |
