- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
JPE
Corrosion around ladder fittings | |
My defender 110 came with an LR ladder fitted.
The paint on the rear panel is bubbling around the bolts fixing the ladder to the panel.
I want to fix this before it gets too bad & looking for advice.
Presumably ladder off (easier said than done, bolts appear seized), rub those small areas down, etch primer & respray?
Any advice appreciated; I don't want to balls it up and make it look worst.
2nd Feb 2020 8:36am |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
