Home > In Car Electronics > Door speaker sound insulation |
Badger110 Member Since: 06 Feb 2018 Location: South hams Posts: 1039 |
The outer skin has a patch of panel dense material ( like dynamat ) already on it so adding more won't do much.
A closed cell foam will be helpful although probably not a huge amount. You will need to strip the window and gubbins out to get to fix to the outer panel succesfully as there is alot going on in the door. |
2nd Feb 2020 5:23pm |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 |
Thanks for the advice
2nd Feb 2020 5:27pm |
