Home > V8 > Belt routing correct? |
PFS Member Since: 23 Oct 2012 Location: Wisconsin Posts: 7 |
So I'm guessing that my post count isn't high enough to enable me to post pictures. I'm not sure how many it is, but this will add one!
29th Jan 2020 3:16pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6605 |
You need to click/tap the pics to add them to your post
I've done it for you now 1988 90 Td5 NAS soft top 2015 D90 XS SW |
29th Jan 2020 3:20pm |
Lodelaner Member Since: 04 Feb 2010 Location: Lambourn Posts: 631 |
It isn't a very clean solution - but it is correct for a 94 NAS. The alternator drive belt runs over the PAS pulley guide wheel and takes its drive from the crank pulley. This wheel doesn't need grooves to grip, it simply guides the belt and over time the belt. If I recall that pulley is smooth from new - it looks like the belt has made an impression on the wheel over 140,000 miles! True, the crank pulleys are different sizes - but so is the PAS pulley which runs at the same ratio - so they run at a similar if not the same speed. What looks out is you ancillary mounts and adjustment - the alternator belt looks like its been adjusted outwards to compensate for belt stretch. Have you tried renewing the belts lately? Check the mounts, bolts and the alternator mounts haven't become bent/oval over time. JB @Lodelaner Instagram Youtube greenlaning and other LR related content |
29th Jan 2020 5:11pm |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2526 |
Definitely need to realign the alternator as it won't be doing the bearings any good with that amount of side load. Defender 90XS SW
29th Jan 2020 6:12pm |
Awesome. Thanks for the help with the pics and the belt situation. The belts have about 10k miles on them, but I'll replace. Now that I know that this is in fact correct, we can realign as necessary. It always made an odd sound when it was humid out and now that the motor is out of the truck, I can better see why.
I'm getting the frame replaced with galvy as the old one was all tweaked and twisted. I cut it up yesterday with a plasma cutter and when I got through on the first cut, the whole frame sprung about two inches. Click image to enlarge |
29th Jan 2020 10:11pm |
