Home > Maintenance & Modifications > Wheel arch shelf? |
HDshark Member Since: 21 Jan 2020 Location: Edinburgh Posts: 2 |
Hi folks, new to forum having just got my first defender
Looking for ideas on levelling off the load space above arches in my puma 90? Don't particularly want to fork out for a drawer system, and most would be too short for my needs, as I want to be able to store rifles underneath. Are there any options out there to buy just a board levelling off across wheel wells, maybe with a central support for strength? Idea is to have dog box sitting on top, with the underneath area for storage. I'm no fabricator, so pre-made is best! Cheers |
25th Jan 2020 11:13pm |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4218 |
I did that. A couple of lengths of steel box across with marine ply over them. 2007 110 TDCi Station Wagon XS
25th Jan 2020 11:46pm |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3684 |
Trailer board is probably most suitable, and if you can use a saw you should be able to do it yourself, or as suli says, get a joiner to cut it down. A big measurement though is the size of your rifle. My 26” barrelled X Bolt is no where near fitting lengthwise on the floor of my 90 and is mounted higher up. You might get away with something 20” ish.
If by any chance you travel to Yorkshire, I’d be more than happy to cut it down for you with the tracksaw. |
26th Jan 2020 8:31am |
deaallen Member Since: 15 Feb 2016 Location: Basingstoke Posts: 264 |
This is what I did, 3 sections of I think they call it furniture board at homebase, then a section of L plate metal cut down and stuck to each end. Very easy to take in and out as needed.
It made the back a lot more practical for shopping etc and very strong, after putting the front seats down my girlfriend and I spend a night sleeping on top of it with an inflatable mattress with no problems! I later covered it in automotive carpet so it didn't look so homemade but then put bench seats in the back so don't really use it much anymore. It also had the added benefit of deadening the sound coming from the back slightly. Click image to enlarge Click image to enlarge |
26th Jan 2020 8:59am |
Siwynne Member Since: 04 Nov 2016 Location: West lancs Posts: 587 |
Click image to enlarge I did it with a piece of ply and auto carpet. Plenty strong enough. It usually has a transk9 box sat on it. |
26th Jan 2020 9:44am |
Better pics.
Point to note. Dogs can get in and out when box sits on the floor. The old man needs help when it’s up higher. Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge The odd pics are details of how it is secured using roof hooks to load securing rings. I wanted to be able to remove it and leave no trace it was ever there. |
26th Jan 2020 9:49am |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4795 |
^ nice tidy job and with carpet fitted looks OEM 2015 HT XS 90
2008 SVX 90 2000 XS TD5 90 |
26th Jan 2020 9:50am |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1628 |
This is one a friend has done to his 90,
its all dynamat underneath as well. home made side panels work well not sure on the dark head liner and back door but its a fair bit of work and is a tidy job. the drawer doesn't take a massive weight on its current rollers but does work well. the open side takes his camping chairs and bits. its coming out on Monday as he has traded upto a 110 and will be making something new for that one/ Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge |
26th Jan 2020 10:40am |
Adam17 Member Since: 15 May 2018 Location: Within Bedfordshire Posts: 1193 |
some nice work their chaps! Regards
Adam Loving The Duchess The Defender 110 TD5 XS My Defender story - http://www.defender2.net/forum/topic64005.html |
26th Jan 2020 10:46am |
Another issue mine has thrown up is that heavy objects are now at tub side height. I am aware that if they slide and hit it they will dent the sides above the wheel tubs but below the body capping
26th Jan 2020 1:10pm |
m3vert Member Since: 15 Mar 2018 Location: Central Scotland Posts: 162 |
Anyone done anything similar on a 110 DCPU? I am looking for inspiration!
27th Jan 2020 5:02am |
Thanks everyone, there are some brilliant ideas there. Think I will give it a go myself after all!
Cheers |
27th Jan 2020 12:04pm |
