Home > Puma (Tdci) > Roof/Gutter Paint
defender75
2009 Defender 110 Puma 2.4 XS CSW Chawton White
Roof/Gutter Paint
I laugh now every time I find a issue with the quality of my truck. My latest one is the paint on the roof in the gutter is coming off. I am not bringing it to the dealer. I am going to have a local guy fix it but I was wondering if anyone else has had this issue and what you did to fix it. I assume it is the paint over the sealant. I would also assume my whole roof doesn't need to be painted to fix it.
Post #81208 20th Jul 2011 4:24pm
Cannonball
Ireland 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Similar on mine, think it's fairly common. Didn't get any worse over three years without attention.
Post #81212 20th Jul 2011 5:12pm
22900013A
Mine is the same, being sorted under warranty. 2011 110 USW
1973 Series III 1-Ton
1969 IIA 1-Ton
1966 IIA 88"
Post #81218 20th Jul 2011 5:47pm
warren
England 2009 Defender 90 Puma 2.4 HT Santorini Black
Mines been repainted twice along the seam as the paint had cracked. Doesn't look like it's going to last much longer again so may need to go back a third time before the warranty runs out.
Post #81229 20th Jul 2011 6:09pm
LR90XS2011
Galway Green and the same 2.5 years of warranty left so watching if it develops DEFENDER 90 TDCI XS,
Post #81231 20th Jul 2011 6:11pm
Barry
Yep , only had it 3 months and it has already been in once for this. I was looking the other day and it looks/feels very thin in the middle aswell , looks like the primer is peeking through however on each end of the gutter it is so thick it is spongy. Well one more thing to add to the list. 2011 Defender XS 110 Station Wagon - Rejected
2008 Discovery 3 XS Auto (Gone)
1997 Discovery ES Auto 300TDI (Traded in on a flat bed)
Post #81248 20th Jul 2011 7:04pm
Beast
Australia
Mine is the same. First noted August last year on both sides near A pillar. Dealer supposedly photographed it for LRA for a warranty claim, but conveniently "lost" the images. Back at dealer yesterday to have photos done again during service / recall - will see whether LRA honour warranty claim. Fortunately, it ain't got any worse in the nearly twelve months of waiting....
Post #81386 21st Jul 2011 11:24am
bob neville
In for the third time for this problem on Monday. Paint does not want to adhere to the sealant in the gutter.
Bob
Post #81390 21st Jul 2011 11:42am
lrMike
Greece
Did it the first time 4 months after delivery under warranty. Maybe will paint it again now with the service. But I think it will be the same after several moths and I will quit caring.
Mike
Post #81393 21st Jul 2011 11:49am
spudfan
Ireland
3 years and all fine here. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #81455 21st Jul 2011 7:17pm
mse
Several times, i think i mean 4/5 then finally a new roof - new roof was fine for 12 months Mike
Post #81526 22nd Jul 2011 7:22am
Zagato
Yes mine is the same above the drivers door (hairline can't see it in pic very well!). I can't tell on mine but looking at Defender75 pictures it appears that its the sealant that is cracking causing the paint to split. If this is the case there is little point taking it into the dealers to be sprayed over again as it will just crack again shortly after.
If mine gets worse I'll run a line of decent sealant within the gutter. I suppose it could be painted over but I'm not worried, you can't see it and it's better to keep an eye on what it's doing.
Whatever they used back in the eighties was good stuff - rock hard but flexible if you see what I mean, I can't dig it out with a screwdriver! This is a spare Series 3 safari top I have. Rivetted not punched as in todays roof and I wish i could find out what the sealant was! Another useless picture, Rolling with laughter
Post #81532 22nd Jul 2011 7:58am
mse
If you go to the dealers - they can sort the gutters out, looking at my records - attempt no 3 where they stripped out the gutters, resealed (the problem is they dont put enough in) and repainted.
The problem of paint spread to a different area of the roof then,
I have a feeling there is something up with the roof flexing - as the new roof was fine, i bet they sprayed it properly, sealed it properly and bolted it equally properly Mike
Post #81537 22nd Jul 2011 8:49am
