Home > Off Topic > Pressure washers.....what one?
Page 1 of 4 1234>
bear100
I am in the market for a new pressure washer Very Happy Very Happy
To be honest I have had enough of my current Kartcher k7 Evil or Very Mad I hate it!
The hose is just too stiff and constantly coils up on itself, the tools are very hard to change because the spring is so stiff, it leaks, has a big hissy fit if there’s a bit of air in the hose......
So may be time for a change of brand if there’s better out there.
What have you got or can recommend?
Thumbs Up 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #811655 23rd Jan 2020 6:41pm
Vintagepaul
2015 Defender 90 Puma 2.2 HT Santorini Black
I've got a K5 and it suffers from all the same faults, only had it a couple of years but don't see it lasting too much longer so I would also be interested in some decent alternatives. 2015 Defender 90XS HT
Post #811668 23rd Jan 2020 7:50pm
mcma1
I recently bought a karcher professional. Just got fed up with the K series faults. It’s night and day. Will get the model number tomorrow Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #811670 23rd Jan 2020 7:54pm
PCM
I changed to Nilfisk range a few years back as was annoyed at the quality v price of karcher.
The pumps on the nilfisks just last. And the hoses etc.. are a lot cheaper if/when you knacker them.
Far better value and a great tool.
Post #811671 23rd Jan 2020 7:57pm
I have a K5 as well. I couldn't complain for the price I paid to be honest.
Personally I wouldn't want one too powerful, as you could easily do some damage.
Bosch and Nilfisk or whatever it's called is the only ones I can think of off the top of my head. $W33T $0U7H3RN $UG4R
Post #811672 23rd Jan 2020 7:58pm
Joe the Plumber
2014 Defender 110 Puma 2.2 HT Fuji White
If you've got the cash, this is the one. Mine's seven years old and still amazes me every time I use it:
https://www.elitecarcare.co.uk/product/kra...re-washer/
Post #811705 23rd Jan 2020 9:32pm
under_rover
2002 Defender 110 Td5 SW Oslo Blue
Kranzle for me too... I've a k7 model and can't fault it... But as Joe says not cheap, but then again longterm investments rarely are. Cheers
Laurie
90 rebuild thread - https://www.defender2.net/forum/topic62909.html
Post #811720 23rd Jan 2020 10:10pm
Banbury
United Kingdom 2015 Defender 90 Puma 2.2 SW Santorini Black
Moved from Karcher to Kranzle when they launched new units for car detailing. They are literally built like a proverbial tank.
Go for the “Total Stop” Model as this has the auto on/ off for the pump.
I have one with the wind-up reel. This is really handy and saves coiling up all the cable.
The other unit doesn’t have this and it’s a pain to have to manually do this...
Items like seals are cheap and they are very easy to work on. They have a different fitting to Karcher etc. So if you have things like a Snow Foam then you will need an adapter.
Post #811726 23rd Jan 2020 10:42pm
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
I have a Kercher one too. I end up going the morrisons more often than not because theirs is so much more powerful 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #811745 24th Jan 2020 7:06am
Joe the Plumber
It's worth noting that the pressure of a pressure washer is less important to the performance than the flow rate. It's not much use having a really high pressure jet of water if it's only a tiny one.
That's where the Kranzle machines win, because they aren't that much more powerful, but they do put out a lot of flow.
You do need to check your outside tap can actually supply the necessary flow rate of course. I may be able to offer some suggestions if it doesn't...!
Post #811746 24th Jan 2020 7:31am
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
I have a Nilfisk C120 7-6 PCA Pressure Washer and never had a problem although the hose does self coil, this is due to the hose being coiled during manufacture. The hoses have to reinforced to cope with the pressure which makes them stiff. Karcher industrial hoses are pain unless you are running hot water through them. Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #811753 24th Jan 2020 8:40am
Joe the Plumber
The hose on my Kranzle is nice and flexible, and it's nearly 50' long as standard.
Post #811754 24th Jan 2020 8:57am
Lwb97
Wales 2002 Defender 90 Td5 HT Oslo Blue
Kranzle k7 here too. Excellent piece of kit and well worth the money.
Post #811757 24th Jan 2020 9:43am
bear100
Looking like kranzle is the way forward so far!
Seems to tick a lot of boxes, pricey but good quality I’m lead to believe.
Do the kranzles have an option to alter the pressure? 2016 Range Rover Autobiography 4.4 TDV8
Post #811771 24th Jan 2020 12:28pm
walfy
Could do with some help on this. I have a Kranzle 160. Had it at my last house and it worked fine, now moved out into the sticks and my outside tap is 25-30m from my drive. Not enough pressure to run it. I had even thought of placing an IBC unit at the bottom of the garden to feed it but it seems a bit overkill 110 D250 SE HT
110 USW SOLD
RRE HSE Dynamic Gone, wife killed it
VOLVO XC60 R Dynamic with some toys
Polaris RZR 900XP SOLD
Post #811778 24th Jan 2020 3:24pm
Page 1 of 4 1234>
