![]() | Home > In Car Electronics > Work halogen lamp and Reverse led lamp |
GRECO Member Since: 16 Jan 2020 Location: Athens Posts: 6 ![]() ![]() ![]() |
Hi to all. My work lamp (rear) has continuous power supply. I just wonder, when reversing, if I could also have it in addition to the led reverse light? Any thoughts? Thanks a lot! Georgios
MY12 90 SW 2.2 TDCI |
Hi..thanks for bothering..you mean just connect the work lamp wires to the reverse lamp wires? Georgios
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5871 ![]() ![]() |
Basically yes.
To the switch you provide a live from reverse lights, (I got my live from tow bar loom electrics) Permanent live, (you already have this as you have a light) I used a switch that has three settings. 1-on. 2-off. 3-reverse live. It spends all its time in the reverse setting, so every time I select reverse my two rear work lights also light up. If I’m working out the back switch to setting 1 (on) And position 2 (off) is there if anyone wants to be picky about the law saying I’m not allowed the extra lights whilst on the road. (Never happened yet with 3 Defenders, over many years, even getting inspected by VOSA, or during MOT’s.) |
Crystal clear..thanks a lot for your concern..much obliged! Georgios
