![]() | Home > Puma (Tdci) > Puma wont start - remote diagnoses with the missus |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5823 ![]() ![]() |
I would leave until you are home to sort it.
But. When it is previously started how long has it been run for? If not at lest half an hour you maybe taking more power out of the battery than putting into it. What is the immobiliser light doing when locked, and whilst trying to start? If you have a battery charger I would get wife to connect that, leave it doing it’s thing over night, then try starting it after doing a lock, leave, then unlock attempt start procedure. Andy. |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2320 ![]() ![]() ![]() |
Does it turn over for a while? Or just half a second and then stop abruptly (immobiliser) > 110 XS Double Cab
agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324 ![]() ![]() |
Hello guys,
Run for long time previous, good drive. I'm not sure regarding how long it turned over, I'll ask. It's away at in-laws second home and she will have only one, maybe two 'sessions' before I'll be over in a month, and then I'll only have a day with it myself with civilisation (landy suppliers etc.) about 3 hours away return, hence me wanting to try to get as much prep/diagnosis done before I'm there... Would love to get a meter on the battery, but mine are both with me for work! So fuses aren't worth looking at? Any in particular if so? Immobiliser, thats the fob right? Worth trying the other fob? Solved the bowel problem, working on the consonants... |
Very occasionally mine tries to start but will cut. I remove keys from ignition, lock vehicle on fob, wait a second, unlock via fob and try again. Always starts on second try.
It's unlikely to be this but you may as well add it to the list of things for your partner to try > 110 XS Double Cab |
Swollock Member Since: 16 Mar 2013 Location: Wellingborough Northants Posts: 262 ![]() ![]() ![]() |
I am with Hank, my 2008 does this a couple of times a year and I have never quite worked out what I did in what order to cause it. It turns over for a second starts for a second and dies. Locking and unlocking with the fob and leaving it locked for a minute or so always seems to cure it.
Tony 2008 Defender 110 XS CSW Volvo S60 T8 Triumph 1200 Rally Explorer G0UBX |
Thon Member Since: 22 Nov 2015 Location: Salisbury Plain Posts: 696 ![]() ![]() |
![]() Simply arm / lock vehicle on the fob, wait for 10 seconds, unlock on fob and start again. |
The red flashing light in the instrument cluster will tell you (us) what the immobiliser is doing.
Where abouts is the vehicle, one of us maybe nearby to check it out for you. |
I'm not sure that the immobiliser lights to which you refer are actually that reliable or accurate. Mine don't seem to be.
Pat Member Since: 05 Dec 2016 Location: Somewhere new! Posts: 368 ![]() ![]() |
I have to go through this starting procedure "every time" with my spare fob. My main fob works first time every time! So might be worth trying a different fob. It started with a kiss, never thought it would come to this. SIII CSW Safari, limestone, (JAC 914N). Where is she now? It's not a car, it's a way of life! |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20652 ![]() ![]() |
Just press unlock on the fob just before you put the key in, even if doors are already open and you’ll find that will do the trick.
If you unlock the vehicle get in and start you won’t need to. But during the delay for xxx time of left open or not started the doors will be open alarm not set but the immobiliser armed. Hence the start up, then cut out. Usually the red dash led will flash when the immobiliser is active. So if your in the drivers seat, and you see that LED blinking. Don’t start it. It will start then cut. Instead press unlock on the fob, then start it. If you ever disconnect the battery you need to press lock multiple times rapidly to arm everything and sync too. The red dash led will flash fast then slow down and your back to normal. As I said, the start up then cut cycle is deliberate and it means the immobiliser is armed and for good reason. TheThunder Rolls🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
Thanks guys, looks like I need to have a better understanding of this. Discussion revealed other goings on that make issue likely related to something else.
Apparently zero power, no indicators from alarm, no alarm, and no start. Likely battery right? But then why no start with jumpers? Computer/fob needs restart? And what's draining it? Solved the bowel problem, working on the consonants... |
Sorry to hear this isn't your issue... But pleased to hear I'm not the only one with the immobiliser niggle! > 110 XS Double Cab
If opening the door with a completely flat battery, trying to start, then attaching jump leads and having another attempt, will probably confuse the hell out of the alarm system.
I'm thinking:
Attach jumpers Start car running that I'm jumping from Wait 5min? Blip the blipper 4 times (or whatever it is that you do after a battery disconnect?) Attempt start ... ah but then, what drained it?? ![]() |
