![]() | Home > Maintenance & Modifications > Metallic Clank/Clunk/Bang |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5797 ![]() ![]() |
Damper rubber mounts, and prop UJ’s would be my first check. Yes you had new UJ’s before, but they can fail.
The suspension was also changed back in the summer. with new damper bushes
![]() ![]() ![]() Click image to enlarge |
BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 903 ![]() ![]() ![]() |
Will definitely give the UJs a thorough check.
The bushes were replaced as they came in the OME kit. However, I will check them for wear later today. Charlie 1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8156 ![]() ![]() ![]() |
check for perishing where that cap on the rear axle located the bush for the shock. they can cause premature bush damage or people do the shocks up so tight the bush is compressed within the cup and its doing nothing.
if you do any off roading i would remove the cup. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
OK, I’ve been out and had a look at everything. The prop UJs have zero play in them. The shock bushes are as you’d expect for their age - still fine. The metal cups for the bushes are more like large washers with the OME kit, interestingly.
I’m using the 90 this weekend so I’ll try and replicate the noise and see if I can narrow it down further. Charlie 1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2273 ![]() ![]() ![]() |
Did you take the props off to check the UJs ?
That's the only way to check them properly. Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
No I didn’t. But I’ve given them a good push/pull and watched them whilst rocking the vehicle. Charlie
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20594 ![]() ![]() |
You still won't know what the UJ's condition is like with them in situ.
I found this too, and MOT stations missed it and so did servicing because the prop want taken off to check. This caused other issues elsewhere and made it more expensive and longer lasting than it need have been. Just removing diff end would be enough to check though. Take a look at upper rear damper mounts too, bounce the body and look for play. Play Stupid Games, Win Stupid Prizes. Big Brother is Watching. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
The obvious has been mentioned by me or others yet.
Is it your rear door, or spare wheel carrier. They are very well known for banging about and require adjustment. |
I’ll have another look at the UJs then.
I did wonder if it was something like the rear door as, once or twice, it sounded like the noise came from inside. I’ll double check but I think I had a look at the door and carrier last week. Charlie 1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
Jack or wheel brace, where ever that may be, even in the battery box.
Ah, it could be actually. I’ve got one of the big Mercedes Sprinter jacks in the seat box and it could have moved slightly. I’ll have a look in daylight. I remember the wheel chock came loose once and sounded like something underneath was about to rattle apart. Charlie
Righto, on my way back from York this clunk has developed . . . It is now a squeak and rattle at low speeds. Am I right in saying that these noises are almost certainly the symptoms of a dying UJ? Charlie
Yep. Sounds like a knackered UJ
