![]() | Home > Maintenance & Modifications > Rear shock absorbers |
SimonDavies Member Since: 15 Mar 2012 Location: Swansea Posts: 244 ![]() ![]() ![]() |
I know this is a subject that has many threads and I have read through a few of them (honest) but I just wanted some clarification.
I have a 2010 90 HT with 86k miles and it has a thudding, knocking noise from the rear load area. I have a bit of movement in the door but I don't think it is the cause. I have play in upper and lower shock bushes so am going to start there but my question is - will upgrading the shocks help the crashy ride from the rear. I'm aware that for the most part, changing the springs is the best option but has anyone changed their shocks and had a decent change in the ride? Ps, is there any other thudding causes I may have overlooked? Thanks |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20612 ![]() ![]() |
Most likely caused purely by the damper bushes, the lowers tend to go first and are easier to replace. The uppers are a bit of a pain. Chillin In The Backwoodsπ¬π§πΊπΈ
β½οΈπ’οΈβοΈπ§°πͺ |
IGP Member Since: 05 Feb 2019 Location: Caverswall Posts: 28 ![]() ![]() |
Recently replaced all my dampers and springs with standard ones. I also fitted spring isolators top and bottom of all the springs. Made a hsge difference to the ride, no more crashing and banging like before.
HTH Ivan |
Thats refreshing to hear. I'm thinking that at 86k miles, my original dampers must be pretty tired so would like to renew them. The fox shocks that you run, are they with the remote Res? |
I'm hoping that is the cause. Based on the mileage I would like to replace them complete, especially if there will be a noticeable difference in the ride. |
What mileage was your Def when you replaced? |
I have the same set up as IGP.
Or at least similar. Genuine springs, genuine castellated isolators top and bottom on the springs. Genuine shocks, and bushes. Just thought Iβd post up here to mention the set up works well. ππ» Chillin In The Backwoodsπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
Thank you. Is your defender a 90 HT also?
Yes it is, I fitted Genuine 90 HT springs myself. I replaced the spring seats as well whilst at it.
On a 90 you can fit the castellated isolators top and bottom all around like I have but on a 110 I believe you can on the front but on the rear you can only use the wrap around spring isolator. On the rear I fitted the wrap around isolator as well. On top of the castellated ones but if I did it again Iβd leave that out as the rear sits a tiny bit higher than it need have been really. Very happy with this set up, it has eliminated a lot of extra road noise and vibrations. Especially on rough unsurfaced routes like Byways and things like that. But it doesnβt feel at all vague either. It will also give you a minor lift, not much but a bit and no other modifications needed either. Chillin In The Backwoodsπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2448 ![]() ![]() ![]() |
I am going back to std, non N filled OEM shocks. Puma 110" SW
X4CAC Member Since: 30 Apr 2018 Location: Midlands Posts: 212 ![]() ![]() ![]() |
Yep those are the ones, probably a bit over kill on all four corners but having driven another 90 with the same setup it was an easy decision |
Mine has done about 190,000 miles. However, when I purchased the car it had HD springs with a 2" lift and gas dampers. It was a very hard ride. HTH Ivan |
