![]() | Home > Td5 > TD5 110 Rear Prop Length |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6163 ![]() ![]() ![]() |
I havn't got the length of the props, but when I swapped from a Salisbury to a 110/wolf/P38 type, the difference was about 8cm longer (longer on the P38 type axle)
![]() Click image to enlarge ![]() Click image to enlarge |
Nidge Member Since: 27 Jan 2008 Location: Kildare Ireland Posts: 821 ![]() ![]() ![]() |
Thanks for reply and pictures Jim .... but its the actual fixed running length i'm after, from rear diff flange to rear flange on the transfer box, as I suspect my chassis mounts are out and the prop is now running over extended, if you get me.
Nigel |
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 546 ![]() ![]() |
Shielder chassis?
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 968 ![]() ![]() ![]() |
Not gonna go under my 110 today snow melting off it right now in the garage. I have a new on eon the shelf and measured it fully compressed 45 1/4 inches.
Hope that helps. Good luck. 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
