![]() | Home > For Sale & Wanted > [For Sale] 285/75/16 BFG AT KO2 on 16 x 7 ET 0 Mods - Set of |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2186 ![]() ![]() ![]() |
Price or have i just missed it??
McS Member Since: 05 Oct 2009 Location: Banbury Posts: 686 ![]() ![]() |
Be interested in a price on these... The Scotia Winch Challenge
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 ![]() ![]() ![]() |
Bargain!
![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8165 ![]() ![]() ![]() |
great tyres and price for the set. i run these on my 90 really pleased with them. Cheers
wyvern Member Since: 13 Dec 2009 Location: Cornwall Posts: 2118 ![]() ![]() ![]() |
sily question -
I am in the market for new tyres and BFG ATR KO2 in particular - what are the benefits in going from the 235/85/16 that I have to the 285/85/16 that are on sale here ?? many thanks Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 ![]() |
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1366 ![]() ![]() |
I wouldn't say theres any pros or cons really. they're a bit taller so some ground clearance is gained.
you have PM ... Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Mr Fudge Member Since: 05 Dec 2013 Location: Near Oxford Posts: 90 ![]() ![]() |
There's quite a bit to consider in terms of pros ans cons - these are effectively 33 inch tyres, not the standard 31 inch. If you have a long range fuel tank in the rear wing (as I do) then the 33's will rub.
So first consideration is height - have you got clearance. Next is gearing - if you're running a 1.4 transfer box they'll be fine, if you're on a 1.2 it will be a bit hard when puling away. (Not sure about TDCi gearing though). Finally width - I've done some back to back vehicle comparisons in sand, wider tyres definitely allow higher speeds / lower power for a given set of revs and tyre pressures. Equally in some circumstances (wet grass for example) narrower tyres can give more grip. Hope this helps. |
Many thanks Mr Fudge .. that is all good to know !
AJC - 2nd PM Sent ![]() Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 ![]() |
deposit taken
Just picked up a full set of wheels and tyres from Andy (AJC) and have already found the noise is about half that with the previous wrangler MTR’s
The ride is a little different too with the taller tyres and the old wheels on the roof. Many thanks to Andy for the cuppa and his outstanding effort in fitting them and helping to load up the old set ![]() ![]() Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 ![]() |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6126 ![]() ![]() ![]() |
^^^ Is that like buying new shoes and wearing them home; putting the old ones in the box?
Smilesapart Member Since: 28 Sep 2013 Location: Suffolk Posts: 735 ![]() ![]() |
Those wheels and tyres make your truck look so cool! What have you put on it now instead? Can we see?
That’s so right Jim, the MTRs will be put to good use on the off road work with 4x4response on my partners 110 (poppy does get muddy but not as serious as my partners 110!) The drive south has found the ride to be much quieter and smoother... just got to work out the best tyre pressures for the set... thinking of 40psi rears and 30 psi fronts ... any advice anyone ? (Pic before adding air to the tyres .....) ![]() Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 ![]() |
