Home > Technical > Glow Plug timer - deep dive questions |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8050 |
Time period against temp info?. Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
9th Jan 2020 7:16am |
itolond Member Since: 16 Jan 2016 Location: Singapore Posts: 193 |
More along the line of how do I know the wait to start is functioning correctly ( with a multimeter) is it just 12v +?
9th Jan 2020 11:24am |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2237 |
Presumably you are referring to the TDi glow plug relay?
If so the glow plug warning light is connected to terminal 2 of the relay. However the other side of the warning light is connected to 12V, therefore the Glowplug relay provides the ground connection to illuminate the bulb. The easiest way to test is to connect a bulb between 12v and pin 2 on the relay to test the function. If you have the rest of the wiring connected to the relay then you can connect a bulb between terminal 2 and terminal 3 which is an ignition feed. Steve 02' 110 TD5 Double Cab Rebuild Thread |
9th Jan 2020 12:13pm |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2301 |
Sorry to hijack your thread but I would also be interested to know what inputs influence glow plug timer on TDCi? As mine heat for maximum duration irrespective of temperature
Cheers > 110 XS Double Cab |
9th Jan 2020 12:30pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6610 |
Tdci is very different as the glow plug strategy is controlled internally in the ECU.
Tdi glow plug "ECU"/timer/unit uses the ignition on trigger, an internal air temperature sensor and a signal from the starter switch (+12V) to determine how long to close the connection between the main power feed in and the glow plug feed out. Edit to add: the ground path for the glow lamp is not necessarily held on for the same period as the feed to the glow plugs is made. The intention being that the glow plugs remain on for a while after the lamp has gone out. 1988 90 Td5 NAS soft top 2015 D90 XS SW |
9th Jan 2020 12:34pm |
