Home > Tdi > Exhaust fitting -any tips |
jeffersj Member Since: 23 Jan 2015 Location: Near Preston Posts: 431 |
Just about to fit middle pipe and box also back box. It was difficult enough getting the old bits away from the hangers so I am wondering if there is an easy way when fitting the new bits to the hangers as the hanger holes seem too small to take the shrouds on the exhaust bits. Jeff
Ex 1968 Series 2A Ex 90 TD5 Ex D3 Ex D4 |
8th Jan 2020 4:54pm |
thanks Tommy. The hangers seem to be held in place on the bar with a washer, is this washer held with a split pin. Its not obvious. Jeff
8th Jan 2020 5:26pm |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 |
Take it to Demand Engineering! James
8th Jan 2020 6:01pm |
Top tips Tommy although did not need to soak in hot water. Greased rubber and inserts and they went on easier than they came off All fitted successfully. Jeff
9th Jan 2020 1:42pm |
