Home > Maintenance & Modifications > Diff oil and swivel pin grease mixing |
jfh Member Since: 08 Jan 2014 Location: West Coast Posts: 359 |
This thread refers:
https://www.defender2.net/forum/topic70611.html So I'm trying to figure out all the parts that I will need to do this job. It's on a 2006/7 110 300Tdi So looking at the attached picture, I will need the following: 7.FTC4785 8. FTC3276 11.FTC3276 (THE GASKET AT 11) 15.FRC2310 21.FTC3646 (THE GASKET AT 21) 22.FTC3648 23.FTC5268 24.STC3435 and a swivel pin seal an gasket LR059968 and FRC4206 Click image to enlarge Does this sound correct? Any input will be appreciated. |
6th Jan 2020 2:14pm |
oneten110 Member Since: 02 Jul 2011 Location: Wish I was still in France Posts: 741 |
Looks about right. Personally I wouldn't bother with the paper gaskets, I would use a gasket sealant type stuff as manufactured by Elring.
http://www.wilmink.nl/Elring/Elring_vloeibare_pakkingen.pdf It is not a Defender, it is a One_Ten |
8th Jan 2020 2:55pm |
windy81 Member Since: 14 Mar 2018 Location: North Wales Posts: 311 |
that dirko smoo is the business
8th Jan 2020 4:12pm |
