Home > Puma (Tdci) > ..Correct engine oil..
Ecco
Malaysia 2014 Defender 110 Puma 2.2 DCPU Galway Green
..hi guys and happy new year..after reading thread about Puma compatible oils, i just wanted to check here, is this oil proper one for my truck (Puma 2.2, MY2014), as it is out of warranty so i want to do oil change myself..here is the link..
Is this one correct??
Post #808662 4th Jan 2020 4:16am
PCM
Mate.
At the top of the page there is a link to a whole list of correct engine oils.
Thumbs Up
Post #808689 4th Jan 2020 11:14am
Ecco
I know, i know, my apology as i haven't explained, i went trough list, but i cant find anything listed there, in Malaysia. So i noticed, that, its mentioned it has to be C3 grade, and i did found this oil, i have posted pic for, so i just wanted some of gurus here, to confirm, is this okay to use or not..
Post #808694 4th Jan 2020 11:30am
I've no idea of the significance but my understanding is that it should be C1 rather than C3. Darren
Post #808699 4th Jan 2020 12:10pm
skidrov
Australia 2010 Defender 110 Puma 2.4 SW Fuji White
Do the Malaysia-spec cars have a DPF? In Australia, none were fitted with one - so wondering if perhaps Malaysia is the same (no reason it should be).
Reason for asking is that your oil choice is simpler if no DPF - you then choose the same oil as the 2.4.
Post #808705 4th Jan 2020 2:10pm
Have a look here if you need a little more info:
https://www.opieoils.co.uk/t-acea-car-engi...ained.aspx
I have no idea of your engine spec, standard RoW or a market specific one?
Post #808733 4th Jan 2020 5:47pm
fatboyron
hello there this is what I use when I service mine it's designed for the ford transit engine so can't go wrong
https://rover.ebay.com/rover/0/0/0?mpre=ht...3729207396
Post #808740 4th Jan 2020 6:13pm
nidge n
I use a Millers 5W 30 synthetic, so i would suggest that you are perfectly ok with this.
Post #808760 4th Jan 2020 8:37pm
Ecco
..my truck has DPF..its 2.2 Turbodiesel Puma, MY2014 110 DC..its stock and nothing has been modified...based on what Supacat posted, it seems C3 is suitable for light trucks with DPF engines ?
Post #808787 5th Jan 2020 3:28am
Julie
France 2012 Defender 110 Puma 2.2 SW Keswick Green
I'd rather doubt that your car is conform to Euro 5 (is equipped with a DP)
If it was it wouldn't work with Malaysian diesel
It seems that Malaysian diesel currently complies to Euro 2.
https://paultan.org/2014/11/17/malaysia-ge...a-mohamed/
Your engine is a ROW type
Get this clarified with Land Rover Malaysia
Post #809087 6th Jan 2020 8:28pm
Ecco
@Julie
..i came back just now, from JLR Service center here in KL...and yes, it turns out that you are correct..trucks sold here do not have DPF installed...only imports(2nd hand), which came in to country trough non JLR , does have DPF, they told me this. Thank you for an insight.
Post #809144 7th Jan 2020 9:23am
