![]() | Home > Td5 > replacing the Fuel Filter housing TD5 |
theheffman Member Since: 21 Mar 2019 Location: bath Posts: 60 ![]() ![]() ![]() |
what is the thinking on replacing the fuel filter housing on a TD5 . £100+ seems like a rip off to me.
This looks well engineered https://goreproducts.com/products/td5-fuel-filter-housing but still! My housing has corroded where the bolts attach it to the chassis. my options are to accept it and pay up or wait to find a TD5 that is breaking and find a replacement from this source. thanks |
As they all seem to fail through corrosion then one from a breaker would seem like a false economy. The Gore unit is a permanent fix. Darren
Oakseywick Member Since: 20 Dec 2014 Location: Cirencester Posts: 1002 ![]() ![]() ![]() |
Get the gore housing fit and forget great bit of kit
![]() Defender 90 Defender 110 XS Cupra 290 |
Also good idea
to isolate aluminium parts from steal parts helps to prolong its life ie. abs plastic between filter head a the chases and under bolt heads and plastic tube over threads |
thanks for your comments, looks like i will go for the Gore fitting.
SteveK Member Since: 21 Jan 2015 Location: Bromsgrove Posts: 334 ![]() ![]() ![]() |
According to their website the housing is out of stock.
