Home > Maintenance & Modifications > Difference between a 90 and a 110 NAS step? |
X4CAC Member Since: 30 Apr 2018 Location: Midlands Posts: 212 |
When I bought mine it came with the fixing brackets for both the 90 and 110 so suitable for either application.
This should help explain the difference... https://www.paddockspares.com/downloads/STC50301_vr1.pdf |
31st Dec 2019 10:03am |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2148 |
As above pretty sure its simply a bracket issue rather than the actual step structure.......
31st Dec 2019 11:46am |
JimC Member Since: 22 Jan 2011 Location: NOVA Posts: 164 |
If it’s a genuine step, then it is an issue of structure. New aftermarket bumpers are built to be universal, the original ones are for a 90 or a 110. A 90 bumper would fit a 110 but the bottom stays would not reach to the frame rail. A 110 Parts would not fit a 90 because the bottom stays would be too long.
31st Dec 2019 12:33pm |
Also be aware there's at least two variants of the rear step bumper. The key difference is in the end flanges where they attach to the rear crossmember.
1st Jan 2020 7:49am |
And I forgot I was replying in a UK forum, so most of what you’re seeing over there is likely the universal-fit variety.
1st Jan 2020 3:01pm |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3674 |
Got it home today, it does indeed fit; just needs the support arms for a 90.
1st Jan 2020 5:37pm |
