Home > Puma (Tdci) > Electrical Gremlins |
RogerG Member Since: 02 Sep 2014 Location: Exeter Posts: 24 |
My 2014 2.2tdci has a strange issue shortly after starting. Initially the radio works but then cuts out and comes back on a few minutes later. During this time sometimes multiple warning lights come on and other times the battery light flashes. I can also hear what sounds like a pulse from the sub woofer and sometimes a sound from the dash fuse box thst sounds like a relay pulsing but I can't determine which one. Usually the radio comes back on but if not I have to restart and then its all back to normal. Does this sound like a faulty relay and if so which one? Any help to sort this annoying problem much appreciated!. Thanks.
13th Dec 2019 9:54pm |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1061 |
Have you checked the nuts on the battery terminals? Are they loose maybe?
15th Dec 2019 9:02am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6602 |
Could be a dodgy ignition switch, the contacts are loose and dropping the connections. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
15th Dec 2019 9:41am |
Thanks, have checked all connections to the ignition switch and the battery and all OK so am at a loss as to know what's causing it.
17th Dec 2019 5:15pm |
Sorry I meant the contacts internally, not the external connections. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
17th Dec 2019 5:54pm |
Tested the battery and it is healthy. Charged it up fully just in case. Same problem. Disconnected the radio, same problem. Checked voltage through cig socket on dash and jt drops down to just over 10 volts when this happens, headlights are dimmer as well then after a while it resolves itself and all ok again.
18th Dec 2019 7:40am |
1. battery have you drop tested it with tester ? may be dead cell with is falling in load
2. have you checked battery neg lead to the chases and transfer box also from chases to the bulk head drivers side for RHD |
18th Dec 2019 8:48am |
