Home > Technical > 300tdi - Oil Leaks for a change - Pic and leak Heavy |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2672 |
The inlet tract is coated with oil in normal use and this is forced out of a blown gasket under the charge pressure.
10th Dec 2019 10:15pm |
90roy Member Since: 21 Jun 2016 Location: Middlesbrough Posts: 130 |
Thanks,
Is it enough to be an obvious leak, enough to drip down onto the exhaust etc...? 300tdi 90 1996. |
11th Dec 2019 10:00am |
oneten110 Member Since: 02 Jul 2011 Location: Wish I was still in France Posts: 741 |
Very much so, the 300 tdi manifold gasket is a very well known weak point, as is the "P" gasket.
The oil leak at the back end of the engine, if not from the clutch housing, could well be the "T" seals on the rear main bearing cap. Another very well known weak point, they can be changed without removing the engine. The intercooler should be flushed every 50,000 miles to clean out all the oil which gets in there. It is in the Land Rover service schedule. It is not a Defender, it is a One_Ten |
15th Dec 2019 2:59pm |
Thanks,
Gasket ordered and I have watched a few YouTube tutorials on how to replace it. Look reasonably straightforward. Roy 300tdi 90 1996. |
15th Dec 2019 6:13pm |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2264 |
A straightforward enough job Roy, order some new nuts too.
15th Dec 2019 8:22pm |
OK, job done and leak cured. Thanks chaps.
1st Jan 2020 4:09pm |
