Home > Technical > 300tdi Oil Pressure Switch |
schweps Member Since: 21 Oct 2014 Location: Zonguldak Posts: 47 |
No advice?
13th Dec 2019 5:14am |
jfh Member Since: 08 Jan 2014 Location: West Coast Posts: 360 |
Most probably just a faulty switch. I would replace it with a good one.
13th Dec 2019 5:29am |
Dave T Member Since: 07 Jun 2013 Location: Glasgow Posts: 490 |
also check the cable I saw one the other day that pretty much just crumbled away 2015 RRS Autobiography SDV6
1994 Def 90 300tdi |
13th Dec 2019 6:24am |
Actually, this is the new one.
13th Dec 2019 8:04am |
Thanks Dave,
I have to check the free cable after separation from the loom, right?
13th Dec 2019 8:08am |
If the wires are okay, then it could still be the switch. New things can also be faulty. |
13th Dec 2019 12:08pm |
Yes, they could be. I'll check.
Since I can read enough pressure on the gauge, it means there is a circulation all around and oil thermostat is doing its job, right? Shall I loosen the banjo connection of the turbo to check the oil? |
13th Dec 2019 2:09pm |
BogMonster Member Since: 05 Feb 2008 Location: Stanley Posts: 400 |
Tdi oil pressure switches can be cheap junk. A number of years ago I went through about six in quick succession, all with similar symptoms. The common factor was that I was, at the time, using a local quarry to wash off the bottom of the vehicle by taking a quick woosh through forwards and backwards. The switches simply were not waterproof, and once water got in, they were knackered.
Don't rule out the switch. The 300Tdi oil pressure light's sole function is to tell you that you need a new switch. I have only ever once seen an engine with a genuine oil pressure problem and that was a new vehicle where somebody had forgotten to put an O ring on the oil pickup when they built the engine, so it was sucking air in at idle. Unless something breaks and dumps the oil, they just don't have oil pressure issues. --- 2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi |
15th Dec 2019 8:13am |
Thanks for your contribution BogMonster.
Yesterday I removed the cable connection and left it hanging in order to check the light. It was still flickering. So the problem was cable, like Dave T. commented. Then I pulled the free cable up and fixed it there temporarily and tataaa, light was gone. I have to replace that cable. |
16th Dec 2019 8:55am |
