Home > Td5 > Wipers suddenly stopped - not fuse? |
Gareth Member Since: 12 Dec 2011 Location: Bramhall Posts: 1102 |
That’s excellent, thank you very much indeed. 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy 1968 S2a 88 aka Bob 2014 Jaaaag F Type 3.0 Supercharged. |
10th Dec 2019 5:38pm |
Well 🥁
Seized wheel box!! Absolutely seized solid. The fact that the left hand wheel box was seized means getting the whole thing out becomes a real dismantling job on the dashboard. Basically I had to remove the whole top, middle, centre panel and instrument binnacle. Now to test if the seized gear has blown the motor. 2021 Defender 110 X-Dynamic HSE D300 MHEV 1966 S2a 109 aka Betsy 1968 S2a 88 aka Bob 2014 Jaaaag F Type 3.0 Supercharged. |
11th Dec 2019 2:29pm |
then you get new wheel box in place, pack the black boot with SILICONE Multi Purpose Grease to give the wheel box longer life and keep water out
Click image to enlarge black boot right hand side pic Last edited by dorsetsmith on 11th Dec 2019 3:31pm. Edited 1 time in total |
11th Dec 2019 2:54pm |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 934 |
Its old , might as well just put a new motor in there anyway.
Glad you sorted it. Cheers 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
11th Dec 2019 3:30pm |
Yes, I think it’s such a to get to, do it properly do it once! 2021 Defender 110 X-Dynamic HSE D300 MHEV
11th Dec 2019 3:34pm |
I forget that just baout everything is easier to get at in my LHD 2010 Range Rover MkIII Autobiography Super Charged (Idris)
11th Dec 2019 3:45pm |
Wiper replacement 2004 model see below
https://www.defender2.net/forum/post528446.html Last edited by dorsetsmith on 12th Dec 2019 10:32am. Edited 1 time in total |
11th Dec 2019 8:05pm |
RobKeay Member Since: 19 Jul 2009 Location: Stafford Posts: 1581 |
I am just in the process of doing mine. The dashboard is quite unnerving to pull apart.
I am told that Landrover allow 16hours to carry out the job. So I keep reminding myself how much I am saving. |
11th Dec 2019 8:25pm |
I am told that Landrover allow 16hours to carry out the job Mine was done in 5 hours by the Indy I use, I can just imagine a stealers doing the job in less than 16 hours, parking the vehicle up then charging 16 hours labour. Don't make old people mad. We don't like being old in the first place, so it doesn't take much to us off. Richard |
12th Dec 2019 10:30am |
you can get to left hand wheel box with out removing hold dash
12th Dec 2019 5:35pm |
In my LDH 110 I was able to change both wheel boxes with only removing the top dash pad. Took about and hour and half. Its fiddley but doable. Done it few times on different Defenders. Not sure how different a RHD would be? I see you can easily access the left side wheel box. 👍🏻 2010 Range Rover MkIII Autobiography Super Charged (Idris)
12th Dec 2019 5:47pm |
Had too change park switch today as wipers had stopped parking then switch off, took the pic to show that you get too the left hand wheel box with most of the dash in place
manage to do the job hr 1.30 with tea brake at the end and rain brake too Click image to enlarge Last edited by dorsetsmith on 12th Dec 2019 11:11pm. Edited 2 times in total |
12th Dec 2019 7:38pm |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2639 |
My local dealer charges 135ish per hour plus VAT . 16 hours labour, may as well wait 5 years and buy a second hand New Defender . Did mine a couple of years back, still have the left over screws ready for next time |
12th Dec 2019 8:32pm |
Finished the job last night. Took me about 5 hours all in. I could have got away with just changing the left wheel box, but decided to swap it all (except motor) as the right wheel box was stiff. Also put a new rack cable in as that was worn where it had been running on the gears.
I reckon the dash has been apart before, as I found a few holes and clips with missing screws and has to raid my supply of spares to finish the job. Also had to hunt out the radio code! 2021 Defender 110 X-Dynamic HSE D300 MHEV 1966 S2a 109 aka Betsy 1968 S2a 88 aka Bob 2014 Jaaaag F Type 3.0 Supercharged. |
13th Dec 2019 2:10pm |
