Home > Puma (Tdci) > Rear seats fixing size
cold
Trying to remove the rear forward facing seats in my 90 to fit some sound deadening. I am struggling to remove the under arch nuts to the point that a couple are stripped so will need replacing but I cant find a spec for the nut - can anyone help? I thought it was an M8 Flange nut but that doesn't fit, a rough calliper check gives me an ID min of 7.7mm which suggests M9 ? but if anyone could confirm size and pitch that would be appreciated
Post #805611 10th Dec 2019 12:00pm
landy andy
Thought they were just M6
Post #805615 10th Dec 2019 12:07pm
cold
Thanks Andy, the socket is a 13mm so assuming bigger than M6 but wouldnt have thought M9 either unless its M8 with a load of crud on it
Post #805618 10th Dec 2019 12:16pm
landy andy
Were M6, M8, and even M10 (seat belt mounts) when I removed mine from memory. No “funny” sizes.
Post #805621 10th Dec 2019 12:34pm
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
Post #805629 10th Dec 2019 1:01pm
cold
Thanks all - it could be crud on an M8 - MacFrank I can't see the fixing in question on your link but I will post an update once I have had a chance to have another go
Post #805632 10th Dec 2019 1:16pm
