Home > Puma (Tdci) > Top end Clicking Ticking
davidpalfreyman
2009 Defender 110 Puma 2.4 CSW Alpine White
Hello,
This issue was mentioned last week but I mistakenly said that the noise was from the air con compressor. The noise occurs at start up but gets much worse when turning on the AC. There is an intermittent clicking or ticking noise from the area round the air con compressor. It is the kind of noise that a solenoid makes when engaging but this is rapid, 2 or 3 times a second but then it slows down, then gets faster etc etc.
It is really hard to see exactly where it is coming from. I removed and inspected the belt and the tensioner, but all seems fine. It sounds like it is coming from the turbo but then if it was the turbo actuating mechanism but I wouldn't think it would get worse when turning the AC on.
Any advice, ideas or musings gratefully received
Thanks
David
Post #805465 9th Dec 2019 2:01pm
petercassidy
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Bonatti Grey
David, did you resolve this issue? Only ask as it seems similar to a noise mine has started making.
Post #834494 31st May 2020 10:19pm
davidpalfreyman
Peter,
I did it resolve it, but not in the way I imagined.
I ordered a new alternator pulley but meantime discovered that the 2 of the 3 rivets that hold the 2 pieces of the top idler pulley were missing. I removed the pulley, and split it in two to find that the bearing was inevitably worn out. Bought a bearing for about £2, put the pulley back together and the noise reduced. After a couple of days, no noise at all. I now have the alternator pulley but have not used it and everything is now OK 4 months on.
If you want any more details, just ask
David
Post #834503 1st Jun 2020 6:32am
petercassidy
Thanks David that's very helpful
Post #834510 1st Jun 2020 7:12am
petercassidy
I'm not sure if the clicking is supposed to happen or not reading through different threads it was commented on as being "normal" when AC is turned on after startin the engine but it doesn't sound right to me.
Post #834511 1st Jun 2020 7:13am
davidpalfreyman
That is how it started with mine, just when the AC was on and then the noise would stop when I turned the AC off. Then it started to make the noise all the time. Now for several months it is OK again.
Post #834549 1st Jun 2020 10:56am
davidpalfreyman wrote:
... 2 of the 3 rivets that hold the 2 pieces of the top idler pulley were missing. I removed the pulley, and split it in two to find that the bearing was inevitably worn out. Bought a bearing for about £2, put the pulley back together and the noise reduced ...
May I ask how you rejoined the two halves of the pulley?
Post #834554 1st Jun 2020 11:25am
davidpalfreyman
Yes, no problem. I used standard aluminium rivets again, but I am keeping an eye on them. The original ones were steel rivets, but they obviously didn't work very well as 2 of the 3 were missing
Dave
Post #834727 2nd Jun 2020 5:42am
andydef90
United Kingdom 2014 Defender 90 Puma 2.2 HT Corris Grey
clicking on a ac unit is normal most cars you cannot hear it Smile
Post #834729 2nd Jun 2020 6:08am
petercassidy
Any chance of a photo where this please?
Post #834771 2nd Jun 2020 11:43am
davidpalfreyman
It is the pulley above the fan pulley to the left. between the fan and the AC pulley.
pullet number 2 on the diagram
Post #834814 2nd Jun 2020 5:00pm
petercassidy
Great thanks, l have a close look at it tomorrow 👍
Post #834858 2nd Jun 2020 8:29pm
