Home > Maintenance & Modifications > Alternator wiring
Barneyboy
England 1986 Defender 90 2.5 n/a Diesel ST Nato Green
Alternator wiring
Hi I’ve today replaced my alternator on my series 2 as the bearings had gone on it, but I can’t get the charge light to go out there are just 2 wires one from the starter solenoid and one from the warning/charge light however they are 2 different alternators and am unsure which to put the charge light too I’ve tried W and it stays on but after looking at the old one it was connected like this
And this is the new one the solenoid I’ve connected to +
Any advice please Thumbs Up cheers Paul
Post #805155 7th Dec 2019 1:20pm
dorsetsmith
Two larger spades DC + out (red )
Small spade charge lamp (orange )
Post #805173 7th Dec 2019 4:05pm
Barneyboy
Hi dorsetsmith thank you Thumbs Up , I have connected the new one with the solenoid cable to this terminal as it already had a ring connector on it can I still leave it on there and just put the charge light on to the small spade connector or should I replace the ring connector with a large spade connector and plug them both in to that same block cheers Paul
Post #805181 7th Dec 2019 4:29pm
Martin
Site Admin
Leave your main power lead as it is Thumbs Up  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #805187 7th Dec 2019 4:50pm
dorsetsmith
Is the terminal marked B+ or D+. ?
Post #805188 7th Dec 2019 4:50pm
Barneyboy
Hi I hadn’t even noticed the letter I just saw the + it looks like B+ Thumbs Up
Post #805197 7th Dec 2019 5:01pm
dorsetsmith
as martin main power lead (starter sol Battery + ) can go to the large spades or the B+ terminal and your charge lamp - IND to D+ or small spade
w terminal is tacho output i.e. RPM gauge
Post #805207 7th Dec 2019 5:27pm
Barneyboy
Hi dorsetsmith and Martin Thank you both very much I will do that in the morning Thumbs Up cheers Paul
Post #805209 7th Dec 2019 5:29pm
Barneyboy
Hi dorsetsmith and Martin Thumbs Up I couldn’t wait until the morning I’ve just been out and fitted the correct spade terminal and fitted it and sure enough the charge light has gone out as soon as it started thank you both very much it’s very much appreciated Thumbs Up cheers Paul
Post #805215 7th Dec 2019 5:56pm
discomog
We're extremely lucky to have Dorsetsmith and Martin on our forum with their expert knowledge of electickery. Barneyboy's problem solved within literally minutes. Thumbs Up Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #805224 7th Dec 2019 6:14pm
Barneyboy
We definitely are 100% Thumbs Up my problem went from a 1/2 hour job to a head scratching afternoon and am very grateful for the advice given and problem solved in minutes Thumbs Up cheers Paul
Post #805228 7th Dec 2019 6:19pm
