Home > Wheels & Tyres > Nordic tyres for UK winters? |
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 672 |
Cooper don't seem to do these in standard 235/85/16 size so not sure if there is a size suitable for wolf wheels. I am thinking about these when I need to replace or have enough of my BFG https://www.nokiantires.com/all-season-tires/nokian-rotiiva-at/ |
6th Dec 2019 9:28pm |
Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5878 |
I've found a 235/75/16, will that not be suitable for a Wolf rim? Does a 10% smaller aspect ratio make any difference if the width and rim size are correct? That equates to a 15mm shorter sidewall. Barely noticeable I'd think. Monsieur Le Grenadier
I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
6th Dec 2019 9:50pm |
jonny Member Since: 10 Mar 2013 Location: North Wilts Posts: 170 |
They are on an Outback (albeit a 3.6R) so it's more waft than nutter-mobile, but they have been totally fine all year round no matter what the conditions, and still have loads of life left with over 20K miles on them.
I probably wouldn't recommend them as a track day tyre but would definitely fit them again (or one of the equivalents - GY Vector, Continental AllSeasonContact etc) for a 'family' car. |
7th Dec 2019 9:53am |
Piggy501 Member Since: 27 Sep 2017 Location: Scotland Posts: 56 |
Regarding Nordic tyres, it's worth pointing out the TyreReviews video won't be totally accurate for a Defender. Most people won't have pure summer road tyres fitted, with A/T or M/T tyres shod on wheels instead. I'd suggest these are already comprised in outright grip compared to road summer tyres, so the true difference between AT/MT tyres and Nordic tyres will be a lot smaller. Personally, I found Nokian Haka LT2s to be a lot better on the road than Goodyear MTRs, both in 235/85R16, in terms of handling feel and road noise. The same was true even when the temperature started to climb in spring, although it really was night and day through winter. The snow and ice performance is remarkable, although having not had a set of decent A/T tyres fitted, I can't offer any comparison there.
CrossClimates seem to be a bit of a miracle of modern tyre technology. Stuck on a FWD estate (heavy but with 215bhp, starting to ask a lot of a tyre) they coped pretty well through snow and ice last winter, and yet this summer, with about 20k miles of wear on them, they coped very well with a... "spirited" drive across the quiet twisties of Scotland to beat a deadline. Two and a bit hours of pressing on, and while obviously they're no semi slick tyre, they gave good road holding and feedback once there was a bit of temperature in them, unlike a lot of other "all season" tyres that start to fade away. I believe this is because they're a summer rubber compound engineered to work winter, rather than a winter tyre bodged to survive summer. Either way, they were good enough I fitted a new set recently. Hopefully some part of my rambling is useful for you. |
8th Dec 2019 12:49pm |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2185 |
All good feedback, cheers
8th Dec 2019 1:25pm |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4230 |
I would argue the difference between winters and most MTs will be even greater. MTs are completely the wrong tyre for any solid surface, including one with compacted snow & ice, especially combined with water or slush. They may be ok in deep fresh snow, which might behave a bit more like mud, buts that's about it. I'm always alarmed when the fist bit of sleet comes and I see a landy charging about on Insa Special Tracks likes it's invincible. I just pray they aren't behind me when they need to do an emergency stop. 2007 110 TDCi Station Wagon XS
8th Dec 2019 1:50pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8162 |
Just to add to the contrast of mt/ats/winter tyres.
I have always run bfg at and at2s through the winter. This year I have experimented with nokian lt2. Both 235.85s. Overall compared to the ats, I have found them better for stopping in the wet and rain in uk. It's not been cold enough for any cold weather comments yet but they have compared favourably on muddy rocky climbs, as just as capable on dirt covered roads. Understand the sips etc but so far have found them an improvement. Not sure that would be the case against cross climate or a less aggressive starting tyre. Oh and they are quieter too. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
8th Dec 2019 6:09pm |
