Home > Td5 > Lack of heat... :-(
Page 2 of 3 <123>
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
☝🏻☝🏻☝🏻 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #804914 5th Dec 2019 9:36pm
Mike c
England 2004 Defender 90 Td5 CSW Belize Green
My td5 heater is more than adequate and gets hot, sure, it takes a few miles to warm up on a cold morning but once its warm it stays like that and I have to turn it down after about 15 minutes so I would say that the op has a problem somewhere.
But then my driving involves rural b roads at decent speed to get the engine warm, sat in traffic this may be a different story, perhaps it depends on type of driving you are doing that determines the heater efficiency? This does seem a common complaint and I am intrigued!
Post #804935 6th Dec 2019 8:12am
excossack
My drive to work is 20 mins, and heater is just getting warm. Recently some motorway driving 25 or 70mile trips produces heat about the same as a 20min drive. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #804940 6th Dec 2019 8:43am
Mike c
Definitely not right Confused
Heater matrix blockage?
Post #804965 6th Dec 2019 11:24am
excossack
I was thinking that. Hoses off and flush through jobbie tomorrow. 1999 Defender TD5 110
Regards
John M0VAZ
Post #804966 6th Dec 2019 11:35am
landy andy
What make was the replacement cooling fan you fitted?
Post #804984 6th Dec 2019 1:39pm
excossack
Aftermarket jobbie. 1999 Defender TD5 110
Regards
John M0VAZ
Post #804987 6th Dec 2019 1:50pm
Mike c
Hope you get it sorted excossack, and would be interesting to know the cause Thumbs Up
Post #805022 6th Dec 2019 5:49pm
excossack
Thanks, so do I. 1999 Defender TD5 110
Regards
John M0VAZ
Post #805141 7th Dec 2019 10:34am
excossack
Water pump test. Cold engine, and top hose bleed screw removed.
To be expected or not? 1999 Defender TD5 110
Regards
John M0VAZ
Post #805154 7th Dec 2019 12:52pm
excossack
Heater matrix flushed both ways and flowed OK. 1999 Defender TD5 110
Regards
John M0VAZ
Post #805168 7th Dec 2019 3:11pm
excossack
Slight update: While the car was in the garage (playing hunt the oil leak) I mentioned the heater issue and they flushed the matrix through with a bit more force than I used with the hose pipe and they felt the heater output was better. I have to agree, it does feel warmer.
Maybe the next step is to replace the matrix.
Something like:
https://www.ebay.co.uk/itm/111825340474?ss...1436.l2649
Which looking at the heater box, remove bolts top and bottom that go to the bulkhead, pull pipes off, and pull heater away from the bulkhead, remove the ring of screws around the top of the matrix and remove it ? 1999 Defender TD5 110
Regards
John M0VAZ
Post #806487 16th Dec 2019 6:05pm
excossack
20 years of heater matrix
Most of the crap on the bin is from the heater box including what looks like a bit of bin bag
After removing the matrix, I poured some fresh water into the matrix and then emptied it out.
Just a bit of crap
The pipes snapped off with worrying ease and some rust
Regards
John M0VAZ
Post #807902 28th Dec 2019 9:00pm
windy81
Wales 1992 Defender 90 200 Tdi HT Firenze Red
Post #807910 28th Dec 2019 10:56pm
excossack
I did look at them originally but I couldn't quite justify the expense of the Alisport one when the heating system should work (and used to) lets see how the replacement matrix goes. 1999 Defender TD5 110
Regards
John M0VAZ
Post #807927 29th Dec 2019 8:46am
Page 2 of 3 <123>
