![]() | Home > Td5 > Lack of heat... :-( |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4801 ![]() ![]() ![]() |
I don't like scaremongering, but those were the exact symptoms I had before I diagnosed my head gasket failure. Or more precisely discovered that my 15p engine had 10p plastic dowels - causing head float and therefore head gasket failure type symptoms.
I changed the water pump first, it was fine. I replaced the thermostat, that was fine. Try removing the jubilee clip off the heater matrix when the engine is running and see if you get air out, by pulling the rubber hose back past the barb on the heater matrix pipe. Mine was getting combustion gasses in the coolant, this was causing an airlock to gather at the highest point in the coolant system (the heater matrix) so no /little heat. Definitely change the water pump first though, it's possible that it's failing /wearing out. ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5938 ![]() ![]() ![]() |
Hi
I hope its not the head as this was replaced with a brand new AMC head around 6 years ago. I have not replaced the water pump and I have owned the car for 8 ish years and has done 225k so maybe.... 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
OsloBlue Member Since: 14 Jul 2018 Location: Essex Posts: 825 ![]() ![]() ![]() |
How is a 15P a 15P if it has 10P plastic dowels? Was it an incorrect service overhaul or? I'm on IG: https://www.instagram.com/osloblue42/ Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html ![]() |
Mine is a very early 15p, typical landrover must have used what they had to hand when building my engine. Installed with plastic dowels. Its the original engine and definitely a 15p. It has the external fuel return and green top injectors. (not to forget the 15p engine number).
When I got it from a landrover main dealer it had a full service history and I requested a warranty work report. The engine had never been touched other than servicing ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
You got me worried now, did you convert to metal dowels? I'm on IG: https://www.instagram.com/osloblue42/
I did yes, no problems since. Although it lasted 125k miles before giving any trouble. Done about 15k miles on the new head with metal dowels. No problems so far
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 ![]() ![]() ![]() |
I have always found this with our TD5. Use of the heater on full before the engine is upto temp means it takes forever to warm up in cool weather. Sometimes it even cools the engine back down again!
I find it quite funny that the TD5 heater is so terrible at heating the car, but actually quite effective at cooling the engine! ![]() Is your viscous fan rotating freely with the engine off (i.e. not seizing up and overcooling the radiator) Steve 02' 110 TD5 Double Cab Rebuild Thread |
I did replace the viscous fan a while ago but have not checked it since. 1999 Defender TD5 110
Notyalc Member Since: 27 Jul 2018 Location: Northumberland Posts: 169 ![]() ![]() ![]() |
Just take the fan off. I don’t think it does much unless you are towing 3500 kg anyway!
Mines off, but I don’t think it makes much difference to warm up time.... |
Is there a method of checking the water pump? I was thinking remove the bleed screw and see if water jet pops out? 1999 Defender TD5 110
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 968 ![]() ![]() ![]() |
Did you have heat before? (And... before what you ask?). Did you do anything to the cooling system recently? If so you may well have an air lock... my heater has been pumping scalding hot air for years. I find the Td5 better than previous versions. 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
I did have heat but over time I think its cooled down a bit and then over summer never really noticed/needed heat. Got the thermostat replaced the other week and better heat was back. But as weather got cooler, I don't have much, certainly not as good as it once was.
Not changed anything for a while on the cooling other than recent thermostat. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Try temporarily putting some cardboard in front of the grill and see if it heats up. Could just be a really efficient radiator or your clutch fan is seized. If so you may need a rad bra to generate more heat in winter months
![]() 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5871 ![]() ![]() |
Get the fan off and see what you got
