![]() | Home > Technical > 1997 Defender Alarm Spider |
DonH2000 Member Since: 12 Jan 2015 Location: North Kent Posts: 551 ![]() ![]() ![]() |
Not sure if this helps but when I owned a 1995 Discovery 1 when I ordered the Spider replacement cable all you did was unplug the Spider module and just plug in the replacement cable. (Getting to the module hidden in the dash was the main problem!).
Of course the Defender Spider could be completely different..... but hope this helps. Cheers Don. |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6145 ![]() ![]() ![]() |
Mine played up in my old company car (300Tdi 110 SW).
I took the spider apart (after drilling the rivets out of the battery box) and it had suffered from the usual dry joints on the PCB. just ran a soldering iron over all the joints, added a little more solder to each one and it was good to go. If it's playing up now.... attack it while it's parked nicely on your drive, not when it lets you down in the middle of laning or shopping when it's p!ssing down with rain etc.... |
Roosterrs Member Since: 19 Feb 2016 Location: Northants Posts: 48 ![]() ![]() |
All sorted dry joints in the end.
