Home > In Car Electronics > Econoseal Crimping Tool
discomog
I'm about to fit a new wiring harness but before I do I want to convert all of the bullet connectors to Econoseal. Can members of the forum recommend a good crimping tool for the Econoseal connectors? Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #804291 1st Dec 2019 1:11pm
Def90
United Kingdom 2015 Defender 90 Puma 2.2 SW Corris Grey
This is what you are looking for but they are not cheap!
Think it was about Β£80 from eBay some time ago.
Post #804292 1st Dec 2019 1:47pm
Martin
Site Admin
Polevolt state their TT351 is for Econoseal:
https://www.polevolt.co.uk/acatalog/Crimp_Tools.html  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #804293 1st Dec 2019 1:50pm
Martin
Site Admin
Same tool appears to be called a TT77 elsewhere
e.g. https://www.ebay.co.uk/sch/i.html?nkw=tt77...mp;_sop=15  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #804295 1st Dec 2019 1:53pm
PaulMc
The PAD-01 kit is good - but, doesn't have the dies to do the proper crimp on the wire seals.
The Durite ratchet tool that Martin has linked to, will crimp the conductor and seals in one operation, on Econoseal and Superseal terminals. Paul.
Post #804304 1st Dec 2019 3:41pm
PaulMc
Cheapest I've found is here -
https://www.autoelectricsupplies.co.uk/mob...ategory/87 Paul.
Post #804306 1st Dec 2019 3:50pm
I just use a cheap non insulated crimping tool. Does the job, maybe a bit slower but works well for me. And you can ensure the conductor is crimped tightly before the sheath and or seals and you can apply the correct pressure by your own judgement. WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #804307 1st Dec 2019 3:59pm
discomog
Thank you guys for all your suggestions. I think I'm going to go for the TT351 (Durite) as suggested by Martin and others. I like the way that it will incorporate the seal when crimping and also that being on a ratchet means that it will only release when the crimp is perfect. Defender 90XS SW
Morgan Plus 8
Post #804365 1st Dec 2019 10:18pm
