![]() | Home > Puma (Tdci) > Retro fitting third row seats in Utility |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2655 ![]() ![]() |
you don't need too much... although depending on how you want to do it, you may have to cut the tubs,
station wagon is stepped where the utility is square.... |
No, the 110 utility uses the same tub as a station wagon. It's 90 hard tops that still have square wheel arches. Darren
That makes it a lot easier then..
MussEd Member Since: 20 Feb 2013 Location: East Lothian Posts: 354 ![]() ![]() ![]() |
Yep definitely the stepped/angled arches in there....so seats plus relevant seat belt bracket and the belts themselves?
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8172 ![]() ![]() ![]() |
Plus the under floor supports. When I picked up my use I asked them to supply the very rear seats and all the brackets needed to fit them. There are alot of extra parts there. Cheers
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17612 ![]() ![]() ![]() |
Even the double-cab uses the same rear tub, ideal if you want to fit a dickie seat for the monster-in-law! |
