Home > In Car Electronics > Radio Interference with Headlights on Full Beam
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
Last week I disconnected the battery do do some welding which triggered the alarm and BBUS as expected. Since then whenever I put the headlights on full beam (and LED lightbar triggered by full beam), there is significant levels of interference from the radio which has never happened before, dipping the lights and the signal returns to normal.
Disconnecting the battery has reset the settings on the head unit but I'm not aware of any settings that would have improved the radio signal itself beforehand. The FM channels are the same frequencies as before and my journey to and from work has remained the same route so it shouldn't be a radio coverage issue.
Anyone have any bright ideas? It's a 2005 TD5.
Thanks, Harry 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #803921 28th Nov 2019 9:23am
sako243
If I understand the problem - you're only getting the interference when you've got high-beam on?
I'm assuming that you still have filament headlights? If that's the case then the first thing I'd check is the light-bar. Disconnect it so that it doesn't come on and see if your problem still exists. If it's a cheap light bar then they've probably got utterly crap constant current drivers for the LEDs in them which got damaged by the welding.
Where was the welding being done? MIG or TIG (steel / ali)? Did you put the earth clamp close to the weld puddle? Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #803933 28th Nov 2019 11:03am
Harry.O
Thanks for the reply Sako243.
The interference is only on high beam, this also triggers an LED light bar via a relay. The headlights are JW Speaker LED units and the light-bar is a cheap version but they have both been on for over a year with no problems beforehand. I'll pull the light bar later and see if that makes any difference Thumbs Up
The welding was to the towing assembly so quite high amp MIG to steel and the earth clamp was also attached to the assembly - circa 8 inches away. The battery leads were removed before we started, which caused the radio to reset to factory settings but I don't think that would have made a difference to anything else? 2005 Td5 110 Hardtop
Post #803940 28th Nov 2019 12:03pm
sako243
Try the light bar first, then perhaps the headlights since they're easy to disconnect.
Failing that I'd suggest swapping out the head unit if possible as that may have also been damaged. Afraid it's just a game of narrowing down the problem.
Another (remote) possibility might be the alternator since when you turn on the high beam it might wind up how much its outputting. Ed
Post #803942 28th Nov 2019 12:06pm
Shax
England 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
A common mode choke in the feed to the light bar will help cut some of the interference.. It works a bit like the suppressor capacitor you put on a petrol distributor... ... ,-------,
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
^^_-^-_^-^_^^^^^--^^^^
PAUL
G7ALW 14.200 USB
26FB458 / 27.275 SSB
Post #804675 3rd Dec 2019 11:35pm
captain slow
United Kingdom 2014 Defender 110 Puma 2.2 CSW Corris Grey
I had a similar problem. Gary @ audiofile (who fixed it) put it down to interference from the LEDs. have a chat with him - he knows his stuff. Thumbs Up https://www.audiofile-incar.co.uk/ he's very good with Defenders 2.2 Tdci 110 XS CSW Corris Grey
Prince Harry's D3 (gone but not forgotten)
300 Tdi 110 CSW (gone but not forgotten)
Post #804725 4th Dec 2019 2:01pm
Harry.O
Thank you for all the replies so far Thumbs Up unplugging the light bar saw the radio signal return with the headlights still on high beam but I noticed this weekend that switching on the rear worklights causes the signal to go again so pretty sure it's the head unit playing up since the switch is located besides the head unit... seems like an excuse to upgrade to DAB!
Post #805432 9th Dec 2019 9:34am
