Home > Puma (Tdci) > puma [tdci] coolant
DOUG MALGARIN
United Kingdom 2009 Defender 110 Puma 2.4 USW Zermatt Silver
puma [tdci] coolant
HI what anti freeze I should use in my 2.4 tdc and best way to drain it .
Post #802860 19th Nov 2019 7:02pm
Motul Inugel Optimal meets specs. (I personally suggest pre mixed but costs some more.)
Personally I used the thermostat hose as the drain point.
*EDITED FOR ACCURACY.* No Guts, No Glory.
Post #802864 19th Nov 2019 7:12pm
LR90XS2011
I've just done mine used Comma Long life OAT, i pulled the pipes of the fuel cooler and it drained down just fine DEFENDER 90 TDCI XS,
Post #802868 19th Nov 2019 7:38pm
*Post corrected above.* No Guts, No Glory.
Post #802873 19th Nov 2019 8:01pm
spudfan
Ireland
I use this from COMMA.
Xstream® G30® Antifreeze & Coolant Concentrate
https://www.commaoil.com/passenger-vehicles/products/view/351 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #803129 21st Nov 2019 9:43pm
LR90XS2011
That's the one I used got it off amazon DEFENDER 90 TDCI XS,
Post #803140 22nd Nov 2019 6:51am
lonewolf
United Kingdom 2010 Defender 90 Puma 2.4 CSW Zambezi Silver
Can anyone tell me what the longevity of the engine coolant is, ie Texaco XLC?
Steve, the motul one from Opie oils you have found looks ideal looking at the specs.
Is changing it all out a difficult job, there appears to be pipework everywhere Neutral
Glen
Post #804629 3rd Dec 2019 6:55pm
Drain from the thermostat drain hose, not too bad a job.
You do need the workshop manual for the bleeding process however or the info may be on here already.
It isn't very complicated, just takes a bit of time,
I changed my own water pump and I'm not an expert mechanic / engineer so you should be fine.
The Motul does meet all specs, in mine I used pre mix and I noticed the running temp was down just a couple of degrees which is good.
On my gauge before it was half way, after a touch below half way in normal conditions.
I'm not keen on the concentrate method as it can introduce a lot of impurities into the system using tap water as it isn't de-ionised and giu can get calcium build up etc etc.
Lifespan is about 5 years so, to me cost on that isn't a huge issue.
Please be responsible with disposal, don't let animals get near it. (Poisonous.) and keep off of paintwork.
But you no doubt already know this.
Thumbs Up
Puma quantity of fluid required is just over 10 litres I think approximately so you need 11L. No Guts, No Glory.
Post #804631 3rd Dec 2019 7:12pm
LR90XS2011
I simply drained mine from the fuel cooler hoses, squeeze and pull off, remove the coolant header tank cap and the screw in the heater hose.
All quite easy and can be done with no tools except a large flat blade screw driver for the top hose screw plug, took me 1 hour max. DEFENDER 90 TDCI XS,
Post #804683 4th Dec 2019 6:55am
X4SKP
I've just topped mine up with the recommended LR OEM Coolant (2.4tdci puma)
LSTC50529 / £13-73(inc) for 1Lt… maybe on a full drain and replace i'll be looking to alternatives... Exclamation
 SKIP
Post #804701 4th Dec 2019 9:30am
lonewolf
Thank you for the info chaps. Two questions though; where is the thermostat and the screw in the heater hose located?
Best to ask to save me rooting around resulting in much head scratching.
Oh, when draining off would a builders bucket (clean of course) be suffice to catch the old coolant as I wouldn’t want to spill any prior to disposal.
Post #804715 4th Dec 2019 12:16pm
