Home > Puma (Tdci) > Puma 2.4 Not Cranking or Starting |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 737 |
Do your AC blower and radio work? If not, then it is most likely the ignition switch that needs replacing.
Also make sure that the battery clamps are REALLY secured to the posts as sometimes they only seem tight but are actually not. I've take to adding a copper sleeve in between the earth post and clamp to ensure proper contact. For the positive post and clamp, I've used a lead shim as you have to really pound it flat to put it on. |
18th Nov 2019 3:03am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17382 |
For the minimal effort it takes, check that the relays under the seat are really tight in their sockets (ie remove and refit them - it should feel as though you are likely to rip the connectors out of the socket when you pull the relay out).
18th Nov 2019 9:57am |
konamac Member Since: 08 Sep 2011 Location: Namibia Posts: 10 |
Hi Blackwolf, thanks for the tip. I have checked the relay and even swapped it out for another similar one to test, no difference when cranking. The relay did slip off quite easily, so for good measure I bent the tabs a little to ensure a snug fit before refitting the starter relay.
18th Nov 2019 1:53pm |
Thanks HardCharger the Ignition Switch powers up all accessories as per usual and supplies power to the correct terminal on crank too. Regarding the battery terminals I have tried starting with two different batteries with slightly different terminal sizes (the one is more snug than the other) and there is no no difference in the end result, absolutely nothing on crank. |
18th Nov 2019 1:58pm |
Update:
I have tried starting with the instrument pack removed and the terminals no's 3 & 4 bridged as described in previous posts on similar problems elsewhere but nothing happens. Same result. Cue more head scratching... |
18th Nov 2019 2:01pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20371 |
If you've a spare jump lead try a temporary ground between negative battery ground and chassis ground or on the engine block or transfer box.
Easy to do, and would tell you if there is any ground fault if any. One a couple of minutes work. You'd be surprised what bizarre effects a poor grounding point can have. $W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
18th Nov 2019 5:04pm |
Thank, will test that a bit later when I get the chance. I think I also need to try turn the starter over direct from the battery too, just to eliminate that completely. Time for the jump lead tests!
19th Nov 2019 6:00am |
UPDATE: SOLVED
Been meaning to update this for a while, but was on leave. Turned out the starter motor had failed, did some tests, most simply a bump start when I had some extra hands and she started first time. Dropped in a new starter, which is a job for a three armed alien with extra long fingers and built in sockets but got it done. So the alarm fault codes were a bit if a red herring and I was able to clear them. The other thing causing confusion during the diagnostics is the tendency of the passive immobiliser to intervene sporadically on cranking. It you lock and unlock on the fob prior to turning the ignition this is eliminated. Thanks all for the assistance. |
15th Jan 2020 6:12am |
