![]() | Home > For Sale & Wanted > [Wanted] LT230 centre diff wanted |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17598 ![]() ![]() ![]() |
I have one of the last type, new take out, never been used, you could have for £50 plus p&p. Not quite what you're after, but they do work (and it would cost you a touch over £1620 from Landrover
![]() ![]() Click image to enlarge |
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 639 ![]() ![]() ![]() |
Thanks,
I’m after the earlier type up to td5 - mine has suffered a failure of the crosspin and the diff housing is damaged internally. I’ve got new gears and hd crosspin but am not happy using the casing. Stripped my spare lt230 and found it has been shoddily rebuilt in the past and one of the taper bearings has spun on the diff shaft. Might end up putting in an Ashcroft ATB if I can’t find a decent used one. |
klacinak Member Since: 11 Jul 2019 Location: Kunhegyes Posts: 8 ![]() ![]() ![]() |
Hello,
does anybody now that the LT230 centre diff shafts plus housing for the 2007-2016 version are compatible 100% with the 1999-2007 version? I only need the diff housing as the planet gears has bitten the inside surface very strong. Of course I will pay all packing and postage costs. I have an LT230 81D type. Thank you so much! |
Yes, they are interchangeable.
