Home > Td5 > Should I do the gasket and dowels?
souster4
Hi All
Its been a long while since I had a defender. Anyway, back here again and hoping you experts can help me.
I've got a 2000 90 TD5, with the 10p engine which has 95k miles on the clock.
It has been running rough but a new injector loom and freeing off the waste gate has helped a load.
So, should I do the head dowels and gasket? Temp and running seems decent. No blowing out the dipstick or filler, and coolant seems fine. No diesel in the sump as I've had that off for the oil pump bolt.
Thanks alot
Post #802753 18th Nov 2019 9:30pm
jst
from your last three sentences no, i wouldnt. at this stage i would run it around for a while and see if it has any head problems. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #802776 19th Nov 2019 9:30am
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
☝🏻 Totally agree, the axiom if ain’t broke don’t fix it applies here Thumbs Up 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #802821 19th Nov 2019 3:22pm
