![]() | Home > Technical > Heater inlet plug/drain - how useful? |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2203 ![]() ![]() ![]() |
cheers for the info
where are the others on the Puma specifically please?? |
![]() Click image to enlarge only trouble is JLR only sale you hole thing Puma specifically |
This is the primary reason that I've fitted a 'snow guard' - it keeps the rain and crud out of the heater duct in the first place. Darren
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20652 ![]() ![]() |
This is the approximate locations of the 3x drains.
One is closer to the inlet the other two are in line with each other just before the outlet all in the same section of plastic ducting. Last time I looked I could only seem to find aftermarket ones, but they are just as good on such an item. The areas marked in red is their location approx. As expected the rear two are a pain to get at. ![]() Click image to enlarge TheThunder Rollsπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
MatLandy Member Since: 11 Sep 2020 Location: Paris Posts: 193 ![]() ![]() ![]() |
You can use the drain valves from the 200TDI (product number MUC2417), they do fit the the Puma air duct holes to replace the original ones. Works a treat, and cheap.
/Mat |
