![]() | Home > Puma (Tdci) > lights reflection from other cars on the glasses (rear/side) |
chalky Member Since: 09 May 2008 Location: Yorkshire Posts: 483 ![]() ![]() ![]() |
It's perfectly Normal, they all reflect off the back door into the rear view mirror and back again,
I take it you have Snow ? which makes it 10 times worse as all the surroundings also bounce in and out of the cabin reflecting off the glass, Coincidentally....... I first noticed this in Norway, Driving from Voss up the Mjollfjell Valley.......... In the depths of winter. We used to drive from the view in the back window projected in the rear view mirror, Not too bad especially as the walls of snow were often 6 Ft high and kept you on the road, DEFENDER XS CSW 08 TONGA GREEN |
BrunoJ Member Since: 14 Sep 2019 Location: Stavanger Posts: 79 ![]() ![]() ![]() |
No snow yet in my area (Stavanger), and even not in the first 1-2 lines of mountains. But I can imagine how it will looks like. I notices side glasses reflexes as well, when I was "attacked" at driver's side by the cars parked on opposite side of the car (especially when road is turning). As mentioned earlier - quite annoying, especially I'm switching between cars, so don't have it all the time.
I was considering changing the internal mirror position higher (shorter arm), or maybe try to make rear glass tinted (but from the inside?). |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2229 ![]() ![]() ![]() |
same here and i am toying with getting the rear door window tinted (already have factory tinted Alpine & rear side lights)
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17717 ![]() ![]() ![]() |
If you can do it legally, getting rid of the interior rear view mirror altogether results in a big improvement (one advantage of having an IW canopy with a solid flap).
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2058 ![]() ![]() |
One of the joys of Defender ownership!
![]() You will soon get used to the reflections and learn to ignore them. ![]() |
Thanks for your replies. At least I’m not alone with the issue... Which means I’m not the first who attempts to update that. Which seems to me there are small chances to really improve that, otherwise you will know already ...
![]() I’ll let you know in case I find any working improvement of that issue. And maybe there is still someone with any workarounds or ideas. |
GuJa Member Since: 03 Oct 2017 Location: Elsfleth Posts: 21 ![]() ![]() ![]() |
Hello,
I had the same situation - and the only way to overcome the problem is to ignore it or remove the mirror. I tried several things but at least the mirror had to go. The benefit is also that you do no longer need the rear wiper and the heating of the rear window ![]() To improove the field of view I installed the blind spot mirrors from MUD. I'm fine with this solution. Cheers Gunnar |
Bear in mind that in the UK the interior mirror is a legal requirement on vehicles manufactured from 1978 unless you cannot see anything in it due to the configuration of the body.
Prior to 78 the requirement was simply for 2 mirrors one of which must be external and on the offside. |
Thank you for the information. Next summer I want to visit England/Scotland, so I will put the mirror back
MikeJ Member Since: 04 May 2014 Location: Dorchester, Dorset Posts: 41 ![]() ![]() ![]() |
https://www.gov.uk/government/publications...r-vehicles Only a requirement since 2010. Although my 2013 has passed every MOT without an internal rear view mirror. I guess you can argue that the spare wheel provides a body configuration that means you can't really see through the window anyway! |
VVS210 Member Since: 12 Nov 2016 Location: Hampshire Posts: 953 ![]() ![]() |
My old 90 (a 1995 model station wagon) went through numerous MOT tests without an internal rear view mirror fitted with not so much of a mention. Ditto, the 110 DCPU went through 2 MOTs in my ownership without the rear view mirror fitted.
