Home > Td5 > Swivel Ball question.
JOHNT01670
United Kingdom 2006 Defender 90 Td5 SW Zermatt Silver
OK its a stupid question but here goes...
A mechanic friend is overhauling my front swivels and the britpart Teflon replacement balls, upper bearing housing does not accept the replacement pins/bearing we have. (they are genuine LR ones)
It also doesn't have a retaining bevel inside to prevent a bearing from dropping through.
Is the Britpart upper bearing unit different to the genuine land rover one?
Have I purchased a dodgy ball with unfinished upper bearing housing.....or the wrong flaming ball unit...
Cheers 2006 TD5
2002 Honda Transalp 650
1995 Yamaha Vmax 1200
2014 Nissan Juke (wifes)
Post #802112 13th Nov 2019 5:40pm
Rich1968
As I understand it,
DA3179 - questionable quality
DA3179G - genuine OEM
Just been looking at them myself.
About £35 price difference.
Rich
Just noticed - dont think I answered your question but you get the point..........
Post #802135 13th Nov 2019 8:11pm
JOHNT01670
Thanks Rich,
Just checking with the supplier in case they have sent me an earlier pair of balls - with the top bearing mount being smooth and will not stop the bearing slipping inwards - its also about 5mm smaller than the lower one.
Cheers 2006 TD5
Post #802138 13th Nov 2019 8:19pm
dorsetsmith
Look like Swivel Ball for Railko Bush Upper Pin FTC105
Post #802143 13th Nov 2019 8:40pm
JOHNT01670
That was my concern Dorset, this would appear to be an earlier ball then..... 2006 TD5
Post #802144 13th Nov 2019 8:43pm
dorsetsmith
yes
Post #802146 13th Nov 2019 8:46pm
dorsetsmith
top hole in swivel ball 41.29 mm
lower hole in swivel ball 42.66 mm for 606666 Bearing-taper roller, Lower
Post #802154 13th Nov 2019 9:08pm
JOHNT01670
Cheers Dorset,
Hole sizes confirmed....bought wrong balls.... Big Cry Big Cry Big Cry
looks like these will be going up for sale shortly.., 2006 TD5
Post #802156 13th Nov 2019 9:14pm
dorsetsmith
FTC 5366
Post #802175 13th Nov 2019 11:12pm
