Home > Puma (Tdci) > Idling surges
Page 1 of 3 123>
eutek
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Idling surges
A while ago I noticed that my MY09 110 would idle strangely after a long run on the motorway.
I'd come to a stop, and the motor chugging/rattling (normal diesel sounds) would gradually get more "intense", or louder... almost like a surge (but the RPM would remain the same).
A second later there would be a slight catch or hesitation (almost like it is going to stall), and it would be back to normal.
It'll do this for a short time after as well... Anyone ever have this happen to them?
Post #80205 14th Jul 2011 6:11am
jlerra
Gibraltar 2007 Defender 90 Puma 2.4 XS CSW Java Black
Idle surge
Hi,
I had a similar experience once when travelling through mid Spain when the idle was erratic after filling up with diesel at a petrol station.
I then drained the filter, and refilled with diesel - no problem since!
I put it down to contaminated fuel.
El pepe flamenco JLS
'El Pepe Flamenco'
Post #80220 14th Jul 2011 8:46am
Zagato
Do a search or pm "22900013A" as he started a long thread on this recently with the same problem - possible causes and solutions were mentioned Thumbs Up
Post #80245 14th Jul 2011 12:09pm
4wheeler
Australia 2013 Defender 110 Puma 2.2 SW Chawton White
I had a similar experience with my Defender. I too felt the problem might have been fuel related and drained some fuel from the fuel filter. Water and other rubbish came out. Draining the rubbish from the filter fixed the problem.
The problem arose again after a trip to the bush. Vehicle idle was a little erratic and slight loss of power. Drained fuel from the filter again and water and fine sand was flushed out. Not good! After draining some fuel from the filter the car ran like new.
My Defender runs very smoothly and has a very constant idle. If this changes, the first thing I check is the fuel filter and now drain a little fuel on a regular basis. All water and sand now gone.
Don't drain too much at a time or you will stall the engine by creating an air lock in the fuel line. I found this out the hard way and it did not take much loss of fuel through draining to do this. It is a real pest getting the thing started again with air in the fuel line.
Good Luck!
Post #80246 14th Jul 2011 12:10pm
eutek
Thanks guys for the info.
I thought initially it might be the fuel when it happened in the past, but I've been back to the place I usually use and it just happened after about 1/2 a tank consumed.
I'll dig up 22900013A's thread to see what he posted.
Post #80257 14th Jul 2011 1:11pm
Apynala
Morocco 2009 Defender 110 Puma 2.4 SW Chawton White
Hello,
I had the same, once i've lost the water tank cap, some idles had occured. I've leveled cooling and it never happens again. If you have a T4 or faultmate, look at temperature of the engine when you drive.
Thumbs Up
Post #80322 14th Jul 2011 10:02pm
rev it
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Cairns Blue
My 07 defender has very similar problem, occasionally it will not idle correctly when stopped at the traffic lights, with the revs moving up and down. I have also had the hesitiation and feeling it was about to stall. Then for next several days all is fine? Confused
Had EGR valve changed several months ago, but still got this intermitant problem. Any ideas?
Post #81910 25th Jul 2011 7:48pm
Alexke
Belgium
happened to me too : 4 new injectors replaced in warranty Discovery 4 SDV6 Landmark
F31 320dA Msport xDrive
LR Defender 90SW TD4 Stornoway grey
320d E46
E70 X5 3.0d Sold!
FFRR TD6 - Sold
Post #81992 26th Jul 2011 11:06am
eutek
Thanks for the info guys... something else to keep an eye on.
It hasn't done it since, and does it quite rarely. Very strange indeed.
Post #82003 26th Jul 2011 12:10pm
rev it
Hello, my 07 defender is still not idling correctly in morning, Sad been told it may be fuel pressure relief valve or fuel metering valve, has anyone had either of these changed?
Post #82815 1st Aug 2011 11:34am
Lorryman100
I recently had the fuel pressure rail and metering valve replaced under warranty though that only came about after receiving dtc P1169. The only thing I can suggest is to monitor the fuel pressure at the rail to see what readings you get at idle and at known rpm's ie: 800rpm=? ,1000rpm=?, 2000rpm=? etc,etc. You will need some sort of monitoring tool like the nanocom, hawkeye or msv2 to accomplish this. However if you have a scangauge 2 you can enter a new code into x gauge and this will give you a new gauge for monitoring the fuel rail pressure. The original FPR gauge on scangauge is not compatible with the CANSF protocol but this code does work on CANSF vehicles:
XGauge
New Gauge: Fuel Pressure (if no FPR, Fuel Pressure at Rail).
TXD: 07E00123.
RXF: 044105230000.
RXD: 2810
MTH: 000100570000.
New gauge display name: FP.
Measurement units: PSI.
HTH Brian.
Post #82817 1st Aug 2011 11:54am
eutek
XGauge
TXD: 07E00123.
RXF: 044105230000.
RXD: 2810
MTH: 000100570000.
HTH Brian.
Cool... thanks for the scangauge settings. I'll hook it myself as well and see if this issue applies to my motor.
Post #82825 1st Aug 2011 12:50pm
Lorryman100
It could also be a sticking EGR valve, especially if it is stuck open as this will cause uneven running at idle almost is if it is starving for fuel, although it will be starving for O2 instead. If you have a scangauge 2 then there is an xgauge to monitor the EGR valve:
Xgauge
New Gauge: EGR Duty Cycle
TXD: 07E022113C
RXF: 04628511063C
RXD: 3010
MTH: 03E87FFF0000
New Gauge display name: EGR
Measurement: Percent %
Post #82831 1st Aug 2011 1:38pm
Landyrover
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Java Black
I experienced this - hadn't started the 90 for a few days, turned it over this morning, fine for the first couple of seconds and then it started reving up and down all by itself - only stopped when I began to drive it. Ok after that.
Nick "You know, Marge, mud is nothing more than wet dirt!" (Homer Simpson)
Post #87207 2nd Sep 2011 1:54pm
Landyrover
Hmm, erratic idling apparent on starting from cold again today. Unlike yesterday when it surged up and down the revs, this time they kept dipping, almost to the point where I thought it would stall. This lasted about 10 seconds or so and then sorted itself out. It's booked into the dealers on Wednesday for a few other little problems to be looked at whilst it's still under warranty. I'll add this to the list.
Post #87443 3rd Sep 2011 4:35pm
Page 1 of 3 123>
